Question about Panasonic NN-T993SF Microwave Oven
NN-T945SFX 1250 watts, does not heat and shows error code H98
MicrowaveSvc
  • 9047 Answers
SOURCE: Error Code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming2.gif circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Posted on Sep 15, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Inverter 1200W - NN-SN676S
That code indicates a problem with the magnetron, inverter or control board.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: My microwave shows a H98
That would be a Panasonic inverter failure code, but please reply back with your brand and full model number.
Posted on May 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: broken door latch on mod.nn-t945sfx
Do you mean the part with hook-like projections that stick out of the door, or the part that holds the door switches inside the oven?
If you need to replace the door latches (the hook-like devices in the door) you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can order Panasonic parts from Tritronics here or by calling 866-779-5835.
Posted on Dec 15, 2008
SOURCE: panasonic genious sensor inverter 1300w nn-t664sfx
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
Posted on Apr 08, 2010
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
H98 ERROR CODE ON A PANASONIC M/W NN-SN797S WHAT DOES THE ERROR CODE MEAN?
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
Mar 10, 2011 | Panasonic Microwave Ovens
We have a Panasonic Microwave model number NN-t945SFX. We were using our microwave as a Inveter Turbo Defroster as we prepared our meal. Seconds after, a family member decided they wanted popcorn since...
NN-T945SFX May 27, 2017
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
If it stops after 7 seconds, it likely has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
Panasonic NN-T993SF Microwave Oven Logo
661 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
