Question about BenQ PB6100 Multimedia Projector
Image is blurred and dark
The image it is projecting is blurred and dark and adjusting the options doesn't do anything Suzy
  • 115 Answers
Re: Image is blurred and dark
Have you checked ot by replacing the Lamp?Check it or check the Fly-eye lens for the same.
Posted on Nov 19, 2007
0 characters
3 Points
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar.
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
LC-XG200 bulbs where can I get one in the UK? At the moment my image looks blurred is that caused by the lamp or is some other issue?
In the first instance:
Adjust focus of the projector.
Make sure a projection screen is at least 4.1' (1.2m) from the projector.
Check Projection Lens to see if it needs cleaning.
NOTE : Moving a projector from a cool temperature location to a warm temperature location
may result in moisture condensation on Projection Lens. In such an event, leave a
projector OFF and wait until condensation disappears.
Apr 03, 2011 | Eiki LC XG200 Multimedia Projector
How do you fix, Black/dark line down the edge of the projected image?
I presume this when you are using the computer or component video inputs. try adjusting the PHASE setting
Mar 19, 2011 | ASK Proxima C170 Multimedia Projector
On the left side of the screen the red color is bleeding off the other colors and causing the picture to be blurred. It is not across the entire screen. Just on the left portion. Do I need a new bulb or is...
That is *not* a lamp problem. Definitely sounds like you have a some sort of video processing problem with the red signal. Just to be safe, try a complete factory reset in the menu. Sometimes, the auto-sync and other such functions cause the image to distort. This can happen if the projector is used with multiple image sources and the unit has to resize the image--it does this using mathematical algorithms. If resetting doesn't help, you need to explore repair options...remember, the unit has been around for awhile--shop around the search engines for quotes.
Aug 30, 2009 | Epson PowerLite 5500C Multimedia Projector
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
Sanyo projector image problem
Can you describe the issue?
check out
they can fix this problem for you!
Jan 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Works for a few months?
Is this a new device -?
Check with seller and or makers help site.
Lamps guaranteed for 90 days and Machine for 2 years usually
Jan 15, 2008 | NEC VT465 Multimedia Projector
Adjusting the angle of my cinego?
If you go into the setup menu you will find an option called keystone. You can adjust that up or down until it looks right to you. What it actually does is project an angle image that will look like a square image when it is projected down from your ceiling.
Dec 23, 2007 | Radio Shack Cinego D-1000 Multimedia...
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
677 people viewed this question
Top BenQ Multimedia Projectors Experts
Electro Med Services...
Are you a BenQ Multimedia Projector Expert? Answer questions, earn points and help others
