Question about Refrigerators
MY REFRIGARATOR IS LIQUING WATER ON THE FREZER COMPARMENT AT THE BOTTOM MAKING A BIG PIECE OF ICE NOW I HAVE PROBLEM TO CLOSED THE DOOR
  • 358 Answers
Probably the drain hole inside the freezer in the bottom back wall is clogh,put hot water in it until melt the ice and keep putting hot water to make sure it goes through.When the drain is clogh the defrost water goes down to the freezer floor and freezes up and the drawer stick to the ice.
Posted on Jul 14, 2009
No ice refrigerator freezes runs constantly
SOME OF THIS NEW REF THE FAN WILL RUN CONSTANTLY IS NORMAN THEY USE VERY LITTLE ELECTRICYTY TO KEEP THE COPRESER FROM RUNING TO LONG.PART OF THR ENERGY STAR. THE ICE MAKER MAY BE BROKEN OR NOT GETING WATER. OTHER TINK CK THE ICE CREAM OR FROSEN JUCES TO SEE IF THERY ARE FROZEN HARD IF THE ARE SOFT THE MEENS THE FREZER IS NOT COOLING GOOD AND I/M WILL NOT MAKE ANY ICE IF IT NOT BELOW 10 DEGREES
Feb 21, 2012 | Maytag MFI2266AES Stainless Steel Bottom...
The Ice and water dispenser does not work. The ice maker is working and making ice. There seems to be no power to the control panel on the frezer door.
I had the same problem... is may be a broken wire from the bottom of the refrigerator to the door control panel. Mine has a broken white wire with red stripe. You have to remove the the control box from the front, small screwdriver, pry gently at the two solts at the bottom of the box, it should pop out. Disconnect the connector harness to the box and set it aside. Then you can ohm out the wires to the lower unit by color code (remove the bottom grill -2 screws) to get to the main harness connector. Not a quick job, but mine is now working after I added an external wire from bottom to control box. Next BIG project is to route new wire through the door. By the way Sears service says there is no fix and a new door assembly is $700.
Tai
Mar 21, 2011 | KitchenAid (KSRD22FKST) Side by Side...
My frost free freezer is icing up on the bottom of the freezer. Occasionally find water on floor No
If the ice is clear and frozen on the floor of the freezer the defrost drain line may be plugged causing the water to over flow the
drain trough and leak into the bottom frezer compartment.
This will require a service tech. to remove the rear panel inside the freezer and find the reason for the blockage of the drain line.
ie....
Mold or slime in drain line
Debirs covering the drain inlet hole
Out of spec defrost heater.
If the ice is fluffly like snow then the freezer door may not be sealing properaly.
With the freezer door closed check the door gasket all the way around the freezer door.
If a gap is seen on one side the freezer door may be misaligned.
To realign freezer door remove all ice with a hair dryer.
Soak up all moisture on the metal rails and inside the freezer.
Pull freezer door all the way out unitll it stops serveral times.
This may realign the freezer door.
If not the door slide rails,Track or Roller gears may need to be replaced.
Jan 15, 2010 | LG Refrigerators
Ice in bottom of frezer
make sure your doorgasket is sealing correctly. if the water runs out it shows that the defrost heater is working.
Aug 07, 2009 | Frigidaire FRU17G4JW Refrigerator
Does not get cold enough to freeze ice at times . if i put ice creme in the frezer it becomes very soft. if i put bags of ioce in the frezer they will stay hard.. this with the control all the way up.
your door is probably not sealing properly. close the door with a dollar bill between the closed door if it comes out easy . that is your problem. you need a new door seal
Aug 02, 2009 | Refrigerators
Not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
Jan 02, 2009 | Maytag MSD2754G Side by Side Refrigerator
Does not make ice
Hi! Walt42
Sound like the electrical fill valve to the ice maker is not closing all the way. It may have a piece of something in the valve. You should be able to remove the valve and try blowing through the valve. If in dought remove the outlet line from the valve and see if any water runs out.
InMrFixIt
Oct 23, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
