Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi hd1080 ws65809
Tv working fine then stops when click to turn on it clicks off no picture no sound no nothing
  • Anonymous Jun 02, 2008
    Have Mitsubishi 55" Projection TV. Not sure which model WS-55859 or WS-55909. When turned on, the green light stays on for two seconds, then the tv turns off. TV does not stay on. Was working just fine and playing vcr tape, but suddenly went off and can't turn on now. Maybe has the same problem as previous. TV is approximately 5 years old. Resolution to previous writer can be appropriate. Any other solutions?
  • blackmarket Jul 24, 2008
    HI, I have a mitsubishi hd 1080 an i was lookin at it took it off went to bed tried turning it on the next morning an im not getting any picture. when i hit power it powers up but no picture or sound. is this a common problem an what can i do to fix it?
  • 4,402 Answers
There is a resistor by the high voltage transformer,it has low value and it opens for no reason,he is likely open and does not let the set stay on,if you are familiar with tv service you can replace it and while you are down there check for any over heated areas and resolder them specially the convergence IC.This resistor is located in the back edge of the chassis in the board in the right side and it might be hidden by a plastic casing that covers the high voltage transformer.If you are not too familiar with tv service you should seek the help of a servicer.Let Us know how it goes or if you need more information.
Posted on Jan 10, 2008
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
TV has no picture, shut off in the middle of a show.
There's a part inside of your tv that over heat, when a minute comes it stop because of the heat. Better check with a tv technician or repair man before the damage became worse.
Nov 13, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Good Day, GLENN;
I assume that IHVT was arcing from the side, and the audio is from the TV and not stereo? Or was it the high voltage splitter? Was it plug in or soldered IN? It sounds like you may have bridged a solder joint, unplugged something by accident or something else? Double check your work first of all. Do you still get high voltage? You may poor part. Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
this sound to me is a convergence problem may cost to you 350$ if you want to do it by your self need to buy 2 stk 392 110 but if you dont know nothing about electronics i recomend you ta`ke the tv to a service center
Jul 27, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi ws- 55807 clicking sound
My tv was working fine until now 8-9-08, it would not come on. The timer light comes on and goes off immediately.
Jul 20, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Power Problem
Most likely the power supply is failing, or some other circuit that is causing a safety shutdown.
Without doing the proper tests and diagnistics, it is impossible to accurately speculate the exact fault.
Jerry G.
Jun 01, 2008 | Mitsubishi WS-65819 TV
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi hd1080
I can't disconnect the parent v chip now it is automatically blocking stations
Feb 17, 2008 | Mitsubishi WS-55807 TV
Mitsubishi diamond hd1080
It sounds like you will have to replace the convergence IC's in this TV set. Not a really hard repair to do but you will need to know how to solder and work on solid state printed circuit boards. Good Luck
Jun 29, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
