Question about Sanyo DS32224 TV
The picture has got bigger cutting off the outer edges
The picture has gotten bigger and looks like everything is fatter, can't see the outer parts around screen.
  • smjonesy33 Oct 12, 2008
    OK...but, I don't see that option on the menu....
  • 3 Answers
Change aspect, screen size thru menu
Posted on Mar 15, 2008
How to make a 5 point star
Use a compass to draw a circle the size you want your star to be.
Draw a second, smaller circle inside the first, using the same center point. Make the second circle about half the size of the first.
Draw a line from the edge of the outer circle to the center point using a ruler.
Place a protractor on the line, with the center hole of the protractor over the center point of the circle.
Measure and mark every 72 degrees around the circle (72, 144, 216, 288 and 360 degrees), dividing the circle into five even sections.
Line the ruler up with the center point of the circle and one of the marks you just made.
Draw a line from the edge of the outer circle, through the center point, ending at the edge of the inner circle.
Continue drawing lines as described until you have drawn the five lines, which evenly divide the circle.
Connect the top of one of the lines that touches the outer circle to the lines that touch the inner circle on both sides, forming a point.
Continue to connect the lines around the circle until you have made a five-point star.
  • Make the inner circle larger for a fatter star or smaller for a thinner star.
  • Draw your star on poster board and cut it out to use as a pattern for drawing more.
  • To make a six-point star, measure and mark every 60 degrees (60, 120, 180, 240, 300, and 360 degrees), dividing the circle into six even sections.
  • To make an eight-point star, measure and mark every 45 degrees (45, 90, 135, 180, 225, 270, 315, and 360 degrees), dividing the circle into eight even sections.
  • Quick and easy may want to do this a few times before the final perfect one. This actually made me think. Haven't done geometry in a very long time.
Dec 23, 2014 | Cars & Trucks
Replacing CR1620 lithium battery for Ultramax OB24
For consumers with the Brita Ultramax (OB24), the one with a digital memo. Here's how you can modify the battery housing for replacement.
Important: It is best to take pictures along the way so you know where the parts go during re-assembly.
I attached photos along on bottom of page for easy viewing.
1.) Remove the battery housing unit from the cover. It is easier if you unclip the small cover off from the larger (main) cover to do this. Carefully pry along the edges with a butter knife until the housing is raised up enough for you to pull if off with your fingers.
2.) Turn the housing upside-down (LCD reader faced down). Now carefully cut/slicing along the topside outer edges of the battery unit with a razor blade. Make sure it is cut evenly so that it can be reused as a 'cover'.
3.) After it is cut and exposed, tap the internals out of the clear plastic housing so you can get access to the battery. Stick something thin (such as the newly cut plastic cover) through the battery lever and push the CR1620 battery out. Replace battery, put everything back into its plastic housing.
4. After everything is reassembled with its new battery, put the (cut) plastic cover piece back, hold gently and wrap some clear packing tape such as 3M. You'll have to measure the tapes and cut them to fit. Secure the top portions with tape, then wrap along the sides to secure the rests.
on Oct 28, 2014 | Brita 35530 UltraMax Digital Water...
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
I have a Sears 22 inch lawn mower, model #917.376070, Serial number 121906M-029886. I recently purchased and installed a new blade from the Sears parts store in Milwaukee (part no. 917-141114) and...
The blade only cuts on the outer 4 inches of the blade rotation(diameter). As the mower moves forward, it cuts the full width of the deck. If sprigs of grass are missed or excessive vibration is present, you may have a bent crankshaft. Check and be careful, ejection of the blade hazard exist.
Jul 17, 2017 | Computers & Internet
Bostitich, N16, Nailer I am looking for seal kit, O ring kit, and # 42 Top Bumper please advise if you can help. Daryl Thomas
The parts are available from here:
I have also seen parts on ebay. Look for oring kit on ebay costing about $20. Or bostitch repair kit ork-11 costing about $30. Just search on ebay for "bostitch n16" . Good luck
Jan 11, 2011 | Stanley Bostitch N16 Nailer rebuild Parts...
Location of oxygen sensor and how to replace it When to buy part doesn't look like the one on truck The one on trk. is 3 prong plug that is detachable, and wire goes to a plug that is rectangle about 8...
you may have gotten the wrong part, the new one should have the same plug, it may be fatter, and have slightly longer wire, but it needs to be plug and play, universal ones that you splice in, generally have issues quickly.
Sep 03, 2010 | 1988 Ford Ranger
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
DVD picture is pink
check that all leads are pushed in
Nov 29, 2009 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Sanyo DS32224 TV Logo
516 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
