SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
SOURCE: I have a Whirlpool side
Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. [email protected]
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
SOURCE: whirlpool double door fridge side is not cooling,
sounds like a defrost problem. check to see if there is any frost buildup in the back wall of the freezer. if so, it is not defrosting like it should.
SOURCE: whirlpool gold ice maker problem
