Question about Panasonic PT-53WX42 53" Rear Projection Television
Covergence Hi,my Television was working wonderfully up til roughly a month ago when all of a sudden the colors would get all messed up and not aligned properly.If i shut the television off numerous times it eventually will come back on.As well as at times i will change the channel however every channel will have the same show(no actual change occurred)Can somebody please guide me in the right direction?Thanks in advance!
    Genius:
  • 1,694 Answers
Convergence IC's must be replaced = requires chassis pull...
A repair normally done by skilled technicians ......T.
Posted on Nov 19, 2007
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
Hitachi 43fwx20b.replaced both covergence chips how do you align colors
Convergence chips replacement should correct colors alignment itself if alignment was not changed in service menu.
Please make sure both convergence chips are getting supplies that is approx +18 volts and -18 volts.
Let me know if you have additional question.
Thanks.
Apr 25, 2010 | Televison & Video
I replace the crts green and blue and know good color but cant get my covergence adjusted right what is the best way to adjust the all covergences i know were the two are tabs on the yoke but what does...
You will have to do a manual alignment and center the CRts after replaceing them. You will need the service manual in order to be able to do the alignment manually or you can mess the alignment up real bad. Heres a link where you can order the service manual for your Model they send it electronically within minutes of placeing the order.
http://servicemanuals.vstore.ca/product_info.php/pName/43p8341/cName/phillipsmagnavox
Dec 06, 2009 | Philips 50P8341 50" Rear Projection...
Red and Yellow blurred picture
I had the same problem this week. I tried the convergence thing but it was impossible to fix. I still needed the repairman. He changed two convergence units ($325, parts and labor). Then the tv was still doing the same thing. We had to adjust the convergence and now everything is perfect. You will need your converter
Mar 01, 2009 | Akai PTH5498 54" Rear Projection...
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
Zenith R56W36 covergence problem
you will need to replace conv ic's then auto converge..
Oct 19, 2007 | Zenith R56W36 56" Rear Projection...
Covergence Problem
What exactly are you seeing on the screen? If one of the colors is only slightly off, you should be able to correct it with the standard menu. If one or more of the colors has suddenly taken a dramatic shift, and is curved inward at a side, it means that one of your convergence output IC's has burned out. You should not attempt to realign the convergence if this happens because you will only be messing up all the settings, and when the new IC is installed, the picture will still be out of alignment.
Aug 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
