Question about HP PSC 1210 All-In-One InkJet Printer
How do I clean the printer, where the ink comes out?
    Problem Solver:
  • 7 Answers
There is an option in your printers menu. Go thru the settings and you will se that there is a setting to clean your printers head. You should be set after that.
Posted on Jul 13, 2009
Why are pages coming out striped?
There is probably dirt on the rollers or on the paper carrier. You could try running the printer through a self clean first. Go into the printer settings, menu, locate self cleaning and press that.
Sep 17, 2015 | Canon Pixma iP2600 Photo InkJet Printer
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Nozzle test does not show pattern for either BLACK output; deep clean does not correct problem. both catridges have plenty ink. color displays are ok.
CANON MP780 BLACK DOES NOT PRINT
This is what works for me. Try at your own risk. I cleaned both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The **** separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
Nov 01, 2010 | Canon PIXMA MP780 All-In-One InkJet...
How to do deep cleaning in epson t10
You can only do deep cleaning if you have the adjustment program..
but if you are using CISS ink.. you can do ink charging.. all you need to do is to trick the printer into thinking you have replace a new ink cart.. then it will do an ink charging.. I don;'t know which type of CISS you are using but there are some which comes with a button for you to reset the ink level.. else you would need to move the head into ink replacement position and then remove and insert back all the ink.. press the ink button and the printer will do ink charging similiar to deep cleaning.
May 14, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
Heavy black vertical lines on back of printed page despite go through cleaning functions?
Cleaning only made it worse. The ink is coming from the cleaning assembly, and you need a shop to clean up the ink and install a mylar shield to keep that from happening again. The ink absorber gets plugged and the ink comes up thru the exit rollers.
Nov 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
My photo 924 printer will not print at all the paper comes out blank? What can I do?
check the printer if it indicates that you have run out of ink? then an ink replacement is necessary, but if not, and printer is not giving any indication of ink replacement or if your ink cartridge still has ink try cleaning the printer head using the printer software installed in your computer try this 4 to 5 times if nothing happened then a hardware check up is needed to see what is the cause of the problem
Nov 20, 2009 | Dell 924 All-in-One InkJet Printer
The Colour is not turning out properly when printing.
You should open the software that came with the printer, there should be a head cleaning option,or a maintenance option, repair option, it just sounds like there is some dry ink in the cartridge holder
where the ink comes out of the cartridge. Try the cleaning option then if it does not work,try this 2-3 times, then remove the cartridge and take a q-tip and clean the metal strip that is on the cartridge
and the place where the ink comes out and the place where the ink comes out and comes in contact with the holder, if it is dried ink, you can put a little rubbing alcohol on the q-tip and clean them with it.
If this does not seam to work please post back with any more info and we will try to help.
Mar 25, 2009 | Canon BubbleJet i550 InkJet Printer
Ink not working properly on ip3000
clean the printer so the ink will come out. Don't worry i had the same problem trust me this works!!
Hope it helps
Jul 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
No ink is coming from my ink cartridge?????
Hi, I find this problem occurs when the Print Head dries out. You can buy special cleaning fluid for this. Just google search for "epson 440 print head clean" You can clean the print head yourself with some warm water on a lint free cloth but this is quite messy.
Aug 25, 2007 | Epson Stylus Color 440 InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
