Kenmore 111 stuck mid cycle with water in barrel
Kenmore 111 model 110.244223300 top loader stuck mid cycle with water in barrel It will fill with water but nothing else will happen will not spin , rinse or drain
    President:
  • 1,124 Answers
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Posted on Jul 13, 2009
Fills with water and then nothing kenmore washer model 23822100 type 111
Top load machines will fill with water while the lid is open. Your problem starts when you close your lid. NOTHING happens. I believe this to be your LID SWITCH . Replace or have replaced and you should be OK. GOOD LUCK.
Jul 26, 2011 | Kenmore 23822 Top Load Washer
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My top loader Kenmore type 111 is working fine until it get to the spin cycle. It won't spin and it makes a really loud buzzing sound. like a weedwacker or something. Help!!!
verify that hot and cold water are not reversed and BOTH are turned on. Sounds like water is shut off. Water valves are noisy without water pressure.
Sep 06, 2010 | Kenmore 22642 Top Load Washer
Slow to fill on most cycles, top loader. Kenmore washer takes forever to fill to the level needed to wash clothes.Model # 110 (92284800), Serial #CC0523352.
Turn off the water. Remove the cold water hose from the machine. Clean the sediment out of the screen on the water valve.You can remove the screen with a bent paper clip. Replace the screen after cleaning.
Aug 24, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer wont stop filling
There is probably a plastic tube running from the tub to a pressure switch which controls the water level cutoff on control panel. One can locate this by taking the backcover off and looking at the water level switch and following the tube to the connection on the tub. Tube must fit on level switch tightly for it to work properly.
Apr 27, 2009 | Kenmore 46462 Front Load Washer
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
226 people viewed this question
Top Washing Machines Experts
