Question about Dryers
Not getting hot
Hotpoint aquarius working but no heat
    President:
  • 1,273 Answers
It sounds like it might be several things. Check the air discharge from the dryer where it exits your house, and be sure thet it is blowing strong. If it is not, you may have a partially plugged vent circuit. Don't forget to make sure the lint trap is clear. Unplug the dryer. Make sure that your vent hose and outlet ducting are clear of debris, with no kinks in the ducting. Take the duct outside and clear it out. (Hold it like a "U", so the contents won't spill). Check the inside rear of the dryer, where the duct connects, for debris, lint, etc..
If you have a strong air flow, you may have burned out heating elements. Again, with the dryer unplugged, gain access to the element leads and test for continuity, if you have a test meter and know how to use it. Replace any broken elements. Parts are readily available from most any appliance parts supply house. If the elements test good with adequate air flow, your problem is thermostat related.
Best regards,
--W/D--
Posted on Jul 13, 2009
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Hotpoint aquarius washing machine never gets hot water
Possible that the HOT line is not working, check the hot water inlet line, Check the voltage to the heating element, check the element.
check the wiring.
Click on : Element
Jan 23, 2013 | Washing Machines
Hotpoint aquarius will not heat water
Although I do not know your particular machine I strongly suspect that the heater element is malfunctioning/broken. Even if it is a hot and cold fill it still requires the element to heat the water up to the correct temperature for the selected wash. If it is cold fill only it certainly needs the element all of the time- apart from rinses!
Sorry but it depends now on who you have at hand to repair as to your next step.
John C
Feb 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarius tumbledryer. The drum works but the heaters are not getting hot therefore not drying the clothes. Any ideas?
Check the thermal fuses / sensors mounted on the top exetrior of the heating chamber and also the heating element. Both accessible from the rear of the machine.
Nov 08, 2009 | Hotpoint Dryers
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Hotpoint dishwasher swd6o
all dishwashers don't heat the water themselves. the water supply should be tied into the hot water line under your kitchen sink.
Sep 18, 2009 | Dishwashers
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Dryers Logo
76 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
