Question about HP Officejet 4315 All-in-One Printer
On Control Panel it says the printer is offline...forget how to make it online! HP 4315 All in One
Hi there
Are you absolutely sure the printer is connected securely from both ends of the cable and turned on? If so, try turning it off and on again. Did it come online?
If not, how is the printer connected to your computer? Is it by USB cable, or via a network cable? And also let me know your operating system like XP or Vista etc.
Thanks.
Posted on Jul 13, 2009
    Problem Solver:
  • 6 Answers
This is fixed by doing the following: Go to "Control panel" "printers" double click on "HP 4315." Click on "Printer" on the menu across the top. The drop-down menu has "use printer offline" Uncheck this.
Posted on Jul 18, 2009
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hp deskje d2360 printer showing offline error
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
Printer going offline
unplug the printer's usb cable from computer then re-insert, leave printer switched on during process
Jan 28, 2010 | HP OfficeJet 4315 All-In-One InkJet...
It says its offline how do i fix this mess?
Find your printer listed in Control Panel. (This varies depending upon your Windows version, which you did not specify)
Right click your printer name in Control Panel.
Choose "Use printer online"
Try your print job again.
Dec 20, 2009 | HP Officejet 4315 All-in-One Printer
PRINTER OFFLINE IT WILL NOT PRINT
Try this first, go to control panel and open printers and faxes and then if you see the printer there just right click on it and select use printer Online and then check if you can print now .....
Dec 13, 2009 | HP Officejet 4315 All-in-One Printer
What do i do if my hp printer says..offline ...and there isn't an online option??...it won't print it ..iv'e tried to refresh it but still no answer
You printer is not communicating the operating system. There are many options on how.
First uninstall the printer (make sure you have the printer driver disc).
All the procedure are going to RESTART the system, manual or automatic.
Remember, mostly installation are not power up or connected and wait until load drivers are done. This a normal step.
Or maybe like this example, you're going to set it online.
Please rate me.
Thank you.
Sep 04, 2009 | HP Officejet 4315 All-in-One Printer
My HP officejet 4300 series stopped printing and shows that it is offline. How do I get it back online?
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN.
A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
Aug 04, 2009 | HP Officejet 4315 All-in-One Printer
Computer says printer is offline...HELP
Make sure that the connection of your printer is properly connect, this settings are not detecting the device which to locate the ports its connect.
Connect it properly because this problem is only to make sure not failed to use your printer.
Check it again in your Printer Panel.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
583 people viewed this question
Seeker5211
Seeker5211
