Question about Brother IntelliFAX 2800 Laser Fax
Copies are coming out in various shades of black - like its smeared...
  • 1,959 Answers
Most common cause is a dirty corona wire and or drum. If after cleaning the corona wire and drum the copies are still mostly black and smeared, the drum may be broken. Best of luck.
Greg
Posted on Jul 13, 2009
Toner smears on all print outs. Looking for what part to replace.
Do you mean when the print comes out the toner smears on the paper when you touch it? If so, then it's the fuser that isn't working properly.
However, if you mean when the print comes out there is smeared toner in various places on your print, but the smears are fixed to the paper, then the cause is more complicated and could be caused by a number of different problems within the printer.
Mar 03, 2014 | Xerox FaxCentre F12 Laser Printer
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Black smears on dp2500
it may be the toner collection unit is full. this can cause the toner smears. supply of the toner/?? difficult depending where you are. try your local stationers and or local panasonic dealer
Mar 16, 2010 | Panasonic Office Equipment & Supplies
Copies coming out almost blacked out
Hello sir; Try to make a copy with cover open, then you can see the lamp is on or not, if not then check the thermos fuse at the ned of exposure lamp or exposure lamp, otherwise you ha go to check the drum blade isn't under good condition if everythingare good final you have to replace developer.
May 29, 2009 | Toshiba e-Studio 350 Copier
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Copying spreadsheets
If the lines look like little steps, maybe broken is segments off by about the thickness of a pencil line, try this. Most likely it's the scanner. You can try calabrating it by doing the following. press in order. Menu #1934. You will see a T pop up to the right side of "Ready to Copy". Then press machine status, then scroll until you find maintenance. May be under system settings. When you find maintenance, press enter, then scroll to Shading Adjustment. Or depending on software version, Adjust shading. Place 5 sheets of paper on the glass,, press enter, then when is says "Adjust Shading?" press enter again. Let it print out the sheet. Then try a copy. If that doesn't help, the scanner itself will probably need replacing.
The scanner is the issue. The segments of what is called the CCD are not working properly.
Once you adjust shading, if that doesn't work, the scanner will need to be replaced.
Feb 28, 2008 | Xerox CopyCentre C20 Black and White...
400S Black lines at top of copy
Sounds like the drum is worn out. Usually do 60-70K before replacement. Shading more noticeable at top of copy. Could also before worn upper fuser roller.
Nov 09, 2007 | Canon imageRUNNER 400S Copier
Canon NP7161copier ( Indicates 8z and stops copying)
Dark shades on both side of the paper? Drum cleaning blade or fuser assembly. Check the upper fuser roller and the drum for build up.
Jul 16, 2007 | Canon NP 6551 Black and White Copier
Brother IntelliFAX 2800 Laser Fax Logo
254 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
