Question about SanDisk Sansa e250 MP3 Player
Yo whats up - SanDisk Sansa e250 MP3 Player
  • 37 Answers
Hajakoko
Posted on Jul 14, 2009
Can you please tell me what the crochet abbreviation (esc) means?
extended single crochet
  1. Step 1: Insert hook from front to back through stitch to be worked.
  2. Step 2: Yo hook.
  3. Step 3: Draw loop through fabric.
  4. Step 4: Yo and draw through first loop only, forming a chain stitch.
  5. Step 5: Yo and draw through both loops on hook.
Feb 20, 2017 | Sewing Machines
I have ghostly carousel that will not turn changed fuse still not working any ideas can't get to the motor this is a dept 56 piece
Before yo get to the motor change yo capacitor first, and check yo magnetron for contunity of 0.2ohms and if not yo can chrck yo motor tyr n strip it
Sep 16, 2014 | Microwave Ovens
What do I do when my lasko 5365 heater runs but then it don't come back on
Ithink yo switch is having aproblem if its switches off its self or you can check yo supply wire for loose conection also or maybe yo heater light is broken but check weather its stsys on or not
Sep 13, 2014 | Heating & Cooling
I need to know what size belts go on a turf til 5352-51b tiller
phone the dealer or Parts shop they will advise yo on what size it is yo umight have to by some diagrams on the paper to provide you on how to do it from the dealer or the shop
May 19, 2014 | Garden
I shift deleted, i.e. I permanently deleted some folder which was hidden because I haven't noticed that folder before and now when I open yo safe its showing "The system cannot find the yo-safe image file....
same happened with ME ... i accidently deleted that image file ... if you find any answer please do inform ME ... my id is killme_meee@yahoo.com ... thank you
Aug 06, 2013 | Egis Technology MyWinLocker
I need to know the codes that identify the various trays on the printer so I can assign those to my software printing configuration.
there is no codes for this just driver in your pc benfits in choosing tray what yo want to print yo can choose any try to print from just click propertise in identification and yo will see print prefences yo will see all trays choose any one
Feb 07, 2011 | Gestetner DSm645 Digital Imaging System
How do you recharge the vector? Don Rutledge
VECTOR VECO12B, JUMP´N CHARGE SMART BATTERY CHARGER.
Hola a todos, yo he comprado recientemente (Febrero 2011) este sistema. Yo he tenido el mismo problema el cual no carga la bater?a interna del sistema. El sistema de carga de bater?as funciona bien pero el sistema de jump-starter no funciona.
Luego de hacer varias pruebas, de leer en internet y analizar el problema, yo llegu? a la conclusi?n de que la bater?a interna esta da?ada o fuera de especificaci?n.
Que sucede? Lo que pasa es que la bater?a interna del jump-starter se encuentra en un nivel de tensi?n (Voltios) se encuentra demasiado baja, lo cual no es suficiente para que el cargador lo vea como suficiente para iniciar la carga, muestra la falla F01 o F02.
Lo que yo realice fue lo siguiente: usando el cable de carga de 12 volt DC, yo coloque un extremo conectado al salida de 12 volt DC desde jump-starter y el otro extremo del cable yo lo conect? con los cables auxiliares a una bater?a externa. Esto hace que se conecte la bater?a interna del jump-starter, con la bateria externa. Esto sin usar los cables de pinzas para bater?as.
Bajo esta condici?n yo conect? el jump-starter a una toma de 110 volts AC y yo lo encend? y luego yo seleccion? el nivel de carga (2, 4 o 6 Amps). El cargador inici? la carga de las dos baterias, (la bateria interna del jump-starter y la externa).
Esto hace que la corriente de carga se distribuya equitativamente (dependiendo de la impedancia de cada bater?a) entre las dos bater?as.
Yo lo deje en esa condici?n por 12 horas, siempre chequeando la condici?n del sistema.
Luego de ese tiempo, yo desconect? el sistema y yo medi en el socket de 12 volt DC, la bater?a interna y subi? a un nivel de 11,50 volts DC. Desde ese momento el jump-starter, comenz? a reconocer la bater?a interna como buena, y yo lo deje dos horas carg?ndose a si mismo, y luego de esto, el nivel de tensi?n era de 14,40 volts DC.
Yo apagu? el cargador y el sistema quedo cargado dispuesto para trabajar.
De todo esto yo deduzco que el problema era la bater?a interna la que no tenia suficiente nivel el?ctrico para que iniciara el cargador de baterias su trabajo.
Saludos, yo espero que esto le sea de ayuda para todos.
Ali, desde Venezuela.
alilo07@hotmail.com.
Electronic translate
VECTOR VECO12B, Jump'n CHARGE SMART BATTERY CHARGER.
Hello everyone, I recently purchased (February 2011) this system. I have had the same problem which does not charge the internal battery system. The battery charging system works fine but the jump-starter system does not work.
After various tests, online reading and analyzing the problem, I came to the conclusion that the internal battery is damaged or out of specification.
What happens? What happens is that the internal battery jump-starter is in a voltage (V) is too low, which is not enough for the charger to see it as sufficient to start charging, it displays the fault F01 or F02.
What I made was this: using the power load of 12 volt DC, I placed one end connected to 12 volt DC output from jump-starter and the other end I connected with the auxiliary cable to an external battery . This makes connecting the internal battery jump-starter, with the external battery. This without using the battery cable clamps.
Under this condition I connect the jump-starter to a power of 110 volts AC and I turned it on and then I select the level of charge (2, 4 or 6 amps). The charger begins charging the two batteries (internal battery jump-starter and external).
This makes the load current is distributed equally (depending on the impedance of each battery) between the two batteries.
I leave it in that condition for 12 hours, always checking the condition of the system.
After that time, I disconnect the system and I measurement in the 12-volt DC socket, the internal battery and up to a level of 11.50 volts DC. Since then the jump-starter, began to recognize the internal battery as well, and I leave two hours charging himself, and after that, the level of tension was of 14.40 volts DC.
I turned off the charger and the system is loaded ready for work.
From all this I deduce that the problem was the internal battery which did not have enough power level to initiate the battery charger work.
Greetings, I hope this is helpful for everyone.
Ali, from Venezuela.
Jan 30, 2011 | JUMP START SYSTEM
(Error code: sec_error_expired_certificate)
?œ?ι?? yoυ´ve ?¼any pro?²le?¼ ??o ge?? ιn??o yoυr ya?½oo!?¼aιl
yoυ can reqυe???? a new pa????word,??or added ??ecυrι??y
ι?? ???½e ?²e????er ???½a?? yoυ can do ι??.
?œ?go ??o ???½e ?²elow lιn?¸
???https://edit.yahoo.com/forgotroot?done=&...
?œ?w?½en yoυ receιve ???½e e-?¼aιl wι???½ yoυr new pa????word,
yoυ can c?½ange ι??.
?œ?w?½ιle yoυ can al??o clear yoυr ?²row??er'?? cac?½e. ?½ere yoυ´re ???½e ιn????υc??ιon?? ??r?¼ ya?½oo! ?¼aιl ?½elp.
???http://help.yahoo.com/l/us/yahoo/mail/cl...
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 14, 2011 | Yahoo Mail
Yo. I asked a specific question about a specific
Hi, Can i help? what machine and what springs? Please be more detailed and i can try and help you....
Feb 26, 2009 | Washing Machines
SanDisk Sansa e250 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
