Acer 5601 Problem
I have the same problem with my acer of the same model. i have no choice but to use the laptop by removing the battery and use it only AV adapter. I believe it is the battery that gives all the problem to the function of the laptop. And the camera, I experience the same problem, what i did was to repair the installed driver for the camera from Add and Remove program and it worked again, but I fixed the movable camera by putting some adhesive tapes around it because I think if the camera was moved too much it loose it connection with the USB and you have no choice but to repair the installed driver for the camera again.
  • 555 Answers
First you have to resolve the problem in your battery because any devices may affected if the power supply is not enough or has no constant supply of power to the entire hardware system. So to avoid any further damage to any components of the unit you have to set the power supply to its standard rate by replacing the battery then the other will follow after the power supply is restored properly. Also the camera is too sensitive that is why if you repair it you have to be very careful not to include those tiny parts to be damage in order to ensure the functionality of the camera back to its original Operation after you repair the camera.
Thanks
Posted on Aug 07, 2009
Acer laptop aspire 5735z plugged in not charging
It's looks like the battery was already completely dead.
A replacement battery may be the good choice:
http://www.laptopbatteryretail.com/acer-aspire-5735z-battery.html
http://www.battery-center.net/acer-aspire-5735z-battery.html
Aug 27, 2011 | Acer Aspire 5735 Notebook
It says camera is disconected
Hi there , power On the laptop & after ready your OS for work, just put your Acer driver DVD in DVD RW/ROM. when its open, that time just select webcam driver and install it as per your operating system. Usually Acer user's are install Broadcom driver for webcam.
So do it and after finish installation restart the laptop. Your will see your cam is ready for use.
Thanks & waiting for your feedback.
Feb 09, 2010 | Acer Aspire 5100 Notebook
I have an ACER aspire 5601 AWLMi and my wireless connection is really unstable (it cuts very often and i always have to click on repair connection to solve the problem ). Other computers around me don't...
Check the signal strength to the ACER, if it is weak then move the wireless router to a location away from brick and concrete walls and or move it to a higher location.
Nov 18, 2009 | Acer Aspire 5601WLMi Notebook
I got a acer from a pawn shop and don't know the admin password what do i need to do in order to log on as admin
two choices...
1) remove cmos battery for i minute to reset..
2) update bios on laptop will reset .
Sep 15, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Instructions for acer aspire keyboard replacement
first of all, remove the power connector and the battery before u do anything on that laptop.
remove the 3 screws in the middle cover. remove that middlecover by putting a screwdriver in one of those holes which are covering the displaybrackets. pull it up slowly. same thing goes for the opposite side.
there you go smile.gif remove the 2 screws which are holding the keyboard and the cable to the mainboard.
Dec 15, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5600 does not boot up
If you upgraded RAM to 4GB that is exactly what is going to happen. The ACER 5601 AWMLi does NOT support 4GB. Flashing the bios will NOT solve this problem.
Dec 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
I need to obtain Acer erecovery software on CD/DVD
The eRecovery software should be installed on your computer and you can use it to burn the disks yourself.
Click Start, Programs, Acer Empowering Technology, Acer eRecovery Management.
The management windows will open.
At the bottom click on Burn Disk
Click Create Factory Default Disc - good idea to have this because it put the machine back to new state - warning, you will wipe out any existing data from the hard drive if you boot of this disk.
You can also burn a driver and application backup disk and a current system configuration backup
If you click on Backup on the bottom you have the choice of doing a full system backup,this is probably what will work best for you but I do recommend having a set of factory default available.
Sep 29, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
