Posted on Jul 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam message on esp 7 kodak printer all areas have been checked and no evidence of paper in machine can be detected?
Anonymous
Level 2:
  • Expert 295 Answers
  • Posted on Jul 28, 2009
Anonymous
Expert
Level 2:
Answers
295
Questions
Helped
108754
Points
501
Open rear access door and check out if there is any tape in and around the rollers or any torn paper or any staples there.. turn printer upside down and oprn bottom p[aper tray check out if there is any paper stuck there. take power cord out of printer and again insert it back. ur printer will work fine
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
1helpful
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
1helpful
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Paper jam kodak esp 5 message even though i don't see one how to unjam paper
usually paper jam is at the back of the printer for more information see your printer manuals
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
13helpful
4answers
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
1helpful
Esp 7....Claims to have a paper jam..can not find any paper in machine ..I have unplugged ..still has the same error
Go to www.kodak.com/go/itg and follow online instructions on how to solve the issue. if the issue is not fixed,Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost..
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
