Question about Dishwashers
My dishwasher will freeze mid cycle for a period of about 1/2 hour before continuing the cycle and it is also restarting itself at the end of the cycle. what could be causing this?
  • 6,784 Answers
The timer control module or control board is faulty at this point. you will need to replace the timer or, control board asap. this will fix this issue.
Posted on Jul 13, 2009
My whirlpool gold series dishwasher will not stop running through cycles unless i open the door. It will just continue to run for hours. Any relatively easy fixes before i call backup?
Some dishwashers can run for 4 hours or more normally depending on the options you choose. What do you mean by it runs through cycles is it always changing cycles by itself or is it just the cycle you pick just keeps on going, have you tried a quick wash or 1 hour wash does it do it then? is you hot water hot enough? if not it makes the unit run longer because it has to heat the water up. always run the hot water at the sink to bring hot water up from the water heater to the sing so the dishwasher fills with hot water and not cold.
Dec 28, 2016 | Whirlpool Dishwashers
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Dishwasher stuck in cycle
Hi
I have a similar problem, did you find the cause of the problem?
Geoff
Jan 13, 2010 | Dishwashers
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
Owen Barnes
