Hitachi ultravision 53uwx10ba
My convergence is off with the red and blue and I had a tech out to try and resolve it witha convergence gun. He was unsuccessful and stated I would need a convergence board replaced. I am technical so I figured that I could buy the part and replace it but the three online sites I called said that it was no longer available. There is a repair place that is claiming they can fix it at about 400 with a 175 dollar diagnosis fee. If the parts are discontinued then how will they fix it? I am trying not to get ripped off. Is there a way I can fix the board?
  • jhudgins Jun 11, 2008
    Yes, I have the same problem. Where can I order the IC 's or the Curcuit Board Kit STK392-110 or the upgrade kit STK394-160?
  • 1,694 Answers
1) What is a convergence " gun " ??
2) The circuit board with large IC's is usually repaired....
Part # original STK392-110 upgrade STK394-160E X 2
3) How are your soldering skills??
PS. 400.00 is normal repair price..................
Posted on Nov 17, 2007
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi projection tv 53uwx10ba - the Convergence ICs were replaced. When the PDKP bridge between convergence board and 2nd board is plugged in, it makes a noise. Kept that unplugged, the picture is...
Did set have this problem before you replaced the STKS?
I know these sets very well. If problem is different in any way from before you replaced chips.......double check all soldering or one of the new chips may be defective.
The more you tell me the better I can help.
regards, SD TECH
Aug 18, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My Hitachi UltraVision HDTV won't turn on. The
Convergence has failed. $250 - 300 let a trained tech. do it for you.
Mar 16, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10ba "Ghosting" blurring issue
Let me post a few photos and you let me know if they show something like your problem.
I suspect from your description you have a convergence problem.
If I am right rate this solution as I do this here for free.
Dec 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
Sep 14, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi UltraVision has blue streak on right side of screen.
convergent systems.. I callled Hitachi....
it cost $600 to relpace the part... all 3 colors red yellow blue,.... tech took the part out and will replace it in about 3 or 4 days.
I was told by technician that it was a very very good tV in fact he said he would buy it from me for $300 and take it away.. I am considering that ... but a new one with Picture in picuture will be 2000 or more
Apr 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
323 people viewed this question
Top Televison & Video Experts
