I have a kenmore 60 series heavy duity and the tub quit spinning. motor running but doesn't turn and makes a load noise.
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 14, 2009
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore series 80 washer makes loud knocking noise during spin cycle
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 80 washer only works right on hevy duty load
CHECK SEE IF MOTOR IS SEIZED BY TIPPING MACHINE FORWARD AND SEE IF YOU CAN TURN THE MOTOR BY HAND. IF MOTOR TURNS FREELY , YOU HAVE A START CAPACITOR PROBLEM.
FXIT
Nov 20, 2007 | Kenmore 22422 Top Load Washer
Loud clicking noise at spin cycle
It sounds like you have a motor coupling that has gone bad. Most of the Kenmore top loaders that I'm familiar with are direct drive machines. Which means, they use a motor coupling between the electric drive motor and transmission to run. If you are in the habit of doing heavy loads like comforters, blankets and jeans this can put a heavy burden on the motor coupler and wear it out faster. The coupler is designed to take the burden of the punishment in order to protect the transmission and drive motor and it is common for them to wear out. The coupler is fairly easy to replace and usually runs about $15. It is located inside the machine between the drive motor and transmission under the wash tub. You would have to remove the outside machine casing, the water pump and drive motor to get to it, though. Make sure the machine is unplugged before attempting any repairs involving removal of the drive motor. If you are not mechanically inclined, you may want to seek the aid of a repairman. I hope this helps.
Apr 29, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
