Question about HP Photosmart C6180 All-In-One InkJet Printer
Color cartridge I have a HP Officejet 7410 All-in-One I replaced my color cartridge and it says "remove & check color cartridge". I have done it a dozen times, changed it with a new one, thinking maybe was defective, still same. Can not do anything else with copy machine (cancel, menu...) I tried someone elses idea and went into Printers, right click the printer, go into properties & Advanced, then check off "print directly to printer"...no good
    Problem Solver:
  • 6 Answers
Is it still under warranty I had the same problem and they sent me a new one hope that helps. or you can buya warranty from hp for $24.99 and then call them and tell them the problem and they will surely send you a new one. DO NOT USE GENERIC INK.
Posted on Jul 13, 2009
How do I replace color cartridge in HP 7410 all in one
Hi
open the printer lid (with power on) and wait for the cartridges to move into 'change position'. Then remove/replace cartridge(s) and close the lid.
Sep 18, 2014 | HP OfficeJet 7410 All-In-One InkJet...
My HP 7410 officejet keeps saying remove and check color cartridge. What can I do to clear this message and resume printing?
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper is jammed in the rollers. take color cartridge out to see if anything is blocking the ink, might have a speck of dirt on it. put back in. be careful if you touch it the area of ink dispensary.
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information. hp has an awesome website for trouble shooting
hope this helps, good luck.
Apr 29, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Error message says check color print cartridge. We've removed and reinstalled several times and the message is still there.
Remove the color cartridges and insure that the spring in not loose. Also look at the printer circuit in the back for pin holes.
Feb 01, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Remove and check cartridge--tried it a dozen
its not a software issue.try changing the cartridge if you still face the issue go ahead and clean the copper contacts on the cartridge with a cotton swab dipped in water. Then clean the copper contacts inside where the cartridges sit.
If you still face this issue call in to hp at 1800-474-6836 cauz this could be a hardware malfunction with the printer and so ask for an upgrade you will get atleast a 50% discount on it with hardware as well as phone support on the upgrade and then u can extend the warranty of the whole printer by 3 to 4 years.
Try this hope this will help you
Jun 16, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
G%% color cartridge
You might have a bad cartridge or the contacts that marry to the cartridge to the machine needs to be cleaned.
Hope that helps...
Jun 18, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Color cartridge problem
Check the color side of the carriage....there is a metal piece in there that breaks free from the side and will "stab" the circuitry board that the cartridge comes in contact with...you will probably see a hole in it...I have replaced several print carriages...fairly common problem with all of the HP printers that use the 96 and 97 cartridges...hope this helps
Apr 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
