Question about Nokia 1100
Sync music from my Mac to my Juke phone
When I first plugged in my Juke phone to my Mac, I was able to just drag songs onto the Juke icon and they would show up on my phone's play list. I could listen to them fine. But one day, my phone suddenly showed zero songs. When I connected the phone to the Mac and opened the icon on the computer, the songs were still there. But I can't get the phone to show or play anything now.
I'd appreciate your help. Thanks!
Cara
  • 18 more comments
  • MariMari45 Nov 20, 2007
    i'm having the exact same problem as cara. when i first plugged in my juke (to my mac) i could just click and drag songs into the file. now, although the computer recognizes that the phone is there, i can't sync any files--i'll put music onto the phone (and when i check the phone's music memory it says that memory has been used--so the songs are on the phone) but they don't show up. when i try and play the music it shows that there are zero songs, even though the phone is showing that memory has been taken up.
  • Maren Nov 22, 2007
    I plugged the Juke into the Mac and was able to transfer a couple songs I had chosen, just to try it out. Then when I tried to add more, the number of songs on the phone went to zero even though the computer recognized the phone's storage system.
    Because everyone else has had the same problem, I'm assuming Jukes are not compatible with Macs, is this true?
  • Cephadelic Jan 02, 2008
    I have a mac/juke problem but it is not quite the same. I cannot get my mac to see my juke. I have gotten it to see it about 4 times and have been able to put music on it, but probably about 10 times randomly the mac will just not see the phone. In other words I cannot even get the telechips thing on my desktop even though my phone says that it is ready to sync. I have been unable to try the disk utility fix because my mac has not responded to my juke for 3 days now.
  • Anonymous Jan 25, 2008
    i have the exact same problem what is the solution
  • lilbean69 Mar 13, 2008
    yeeeeeep same thing happend 2 me1!!
  • Mr_What Mar 19, 2008
    Suddenly, my phone lost all of its music files, and gives errors when I try to sync.
    I had plugged it into a Mac to recharge in the past... but the last recharge
    was on a PC, and still, it is dead.
    Windows media player gives errors "unable to unlock secure clock" when trying to synch.
    Is there not a way to re-format the music/data storage area on these phones?
  • mac luver Apr 02, 2008
    I deleted some songs I didn't want anymore from my phone, and when I went to put more on it, it didn't work.  I've never had a problem with a mac that I couldn't solve until now.  any help?
  • Anonymous Apr 22, 2008
    Yup. Same problem. Exactly.
  • mandy_pandy May 04, 2008
    how do i get music to my juke phone??????
  • Anonymous Jun 03, 2008
    I can't separate y music in folders as I want , can you help me
  • zanta1992 Jun 18, 2008
    I have the same problem plus another one. Not only does it not play music but the removable disk that appears isn't named TELECHIPS its TCSYSDIR. I really don't know what that means. If anybody does please tell me. Thanks.
  • jord1 Jun 22, 2008
    My music has no music in it but the telechips folder shows the music i loaded?
  • Anonymous Jul 02, 2008
    how do i get the songs from itunes that are m4p to show up on my juke?
  • Anonymous Jul 09, 2008
    what u do for the samsung juke is creat a music folder and put it in the telechips icon on ur desktop and it will load the songs into the phone and then disconnect the phone and u should have the songs in the phone under ur music
  • Anonymous Jul 18, 2008
    i pluged my juke up to my mac and the songs or there but they dont show up on the juke
  • Anonymous Oct 13, 2008
    i think it had to do with the not ejecting the plug, but when i tried to, it wouldnt work.
  • Anonymous Nov 09, 2008
    mine just wont download
  • achilles619 Dec 22, 2008
    my mac wont show the juke icon.
  • Anonymous Jan 10, 2009
    have never been able to get music file to show anything other than song titles, they're not going into the memory. when unplugged shows zero songs
  • Anonymous Apr 07, 2009
    same :(
Mac JUKE Solution ,I have 416 songs on my JUKE and here is how I did it. Plug your JUKE into your Mac ,turn it on , go to music on your JUKE ,scroll to <sync music> close your JUKE. Look on your desk top for <TELACHIPS> go to Applications then Utilities then Disc Utility. Open Disk Utility click on the <1.9 GB Samsung Drive Icon> select <partition> under format select <Mac OS extended Journaled> run the program . Now you have a Mac Drive an can drop and drag iTunes into the <music. folder inside the TELACHIPS icon . If you have bought music from iTunes DON'T put it on your JUKE it is locked and will screw things up! there are ways to unlock them, It's all on the Internet
Posted on Dec 18, 2007
Connect your Juke phone to the mac. Go to the Telechip folder. Inside the Music folder you must put an Artist folder. Inside that put an Album folder and inside that put your songs. Telechip>Music>Artist's name>Album name>music
Posted on Oct 16, 2008
I had the same problem, the way to fix it is hit the center button, to go to the "menu", then go to "music", select "Sync Music". Hide or minimize all windows and find the "TELECHIPS" folder, which will show up as a white drive right below your "Macintosh HD" icon, open up iTunes and minimise the right side of the itunes window, so you can see the folder on the desktop, drag the music you want from from your iTunes library onto the "TELECHIPS" icon. Once you have done this, pick up your Juke and flip it open, hit the center button to go to "Menu", go to "Settings & Tools" and hit "#", then hit "000000" (zero x 6), press the center button to accept the password, this will allow you into the System Info Menu, now scroll down to "MTP Setting", if it hasn't been working it is probably on the "MTP" setting, now switch it to "MSM" this should disconnect the Juke from your Mac, and you will get a pop up "Device Removal" warning saying "The device you removed was not properly put away. Data might have been lost or damaged. Before you unplug your device, you must first select its icon in the Finder and choose Eject from the File menu." --- now hit clear or end, go back to the menu (center button) and go to music, your music should be there. Disconnect the phone, go to your "Menu" then "Music", close the phone and go to "Artists" or "All" and enjoy the music!
Hope this review helps!!!
--->Don't forget to rate me!<---
Ok, I'm having the same problem. I didn't want to reformat, so this is what worked for me. I plugged the phone to my mac. The TELACHIPS icon appeared. I could see all the songs in the music folder. On the phone I navigated to sync music. Nothing seemed to happen. With the phone still connected I navigated to "My Music". On the mac screen came a window telling me the device was improperly disconnected. Oh well all my songs show up on the phone. This has worked two times. Give it a try!
dg
Posted on Jan 10, 2008
What I've discovered is that if it's not already formatted as a Mac OS Extended Journaled it needs to be, under disk utility raid, but mine already was so I kept trying to figure out why I wasn't able to change it, go figure. It seems they're making them to be able to use them with mac now
Posted on Sep 09, 2008
This problem was same to me this is how i fixed myn I went to verizon for help and brang my mac laptop he said that he will delete everything on my phone to start over. After that we went threw the laptop and then said wait a sec ur problem is that u have AIFF songs and the waay he gounf out was he hit apple I and it told him some info. I said what is that, he told me that i need mp3 songs he went threw all my songs and found three mp3 so he put them on and it worked he then asked me that i could invert the soungs to mp3 i asked how he said he didnt know so after three weeks i found out how All i did was take the AIFF song and placed it in Itunes, then went to prefrences on iTunes, then went to advanced, then went to importing and clicked on Import Using: MP3 encoder, then if u wanted to burn it i changed the disk format to MP3 CD. Once i was done i pressed ok. Then went up on the bar when u are on itunes and it has Advance i clicked on that and went down and found out i fixed it and changed it to covert to MP3 so i coverted it and draged the song on to desktop but it was still on iTunes. which when I had my MP3 songs they were on QuickTime so i held down on the keyboard apple I and went to open with at the bottom and changed it to QuickTime and it worked i could listen to my music
Posted on Apr 16, 2008
I just have no clue on how to put music on myjuke HELP!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 02, 2008
How long does it usually take to download about 50 songs
Posted on May 28, 2008
If you have all your music elsewhere, JUST REFORMAT the JUKE. I was using Vista and Media Player. I was afraid to reformat (using Media Player to do it) because I thought I might erase my contacts. I didn't, and everything is working smoothly now. Perhaps reformatting from Mac OS would work as well.. Probably.
Posted on Mar 19, 2008
I used this methed, it worked. But when I disconnect the phone and reconnect I cant drag and drop anymore. I have to start from the above methed again. How do i fix this?
Posted on Dec 22, 2007
The jukes aren't supposed to be compatible with macs (you're SUPPOSED to use windows media player to sync it). but it doesn't make sense that the juke would work with clicking and dragging for macs and then just stop.
Posted on Nov 26, 2007
When I first plugged in my Juke phone to my Mac, I was able to just drag songs onto the Juke icon and they would show up on my phone's play list. I could listen to them fine. But one day, my phone suddenly showed zero songs. When I connected the phone to the Mac and opened the...
Posted on Sep 23, 2008
Nothing is working for me at all! I plug it into my Mac, the telechip icon pops up- then I am supposed to go to "Utilities" according to the person above, but my Mac doesnt even have a Utilities folder.  I have limewire and iTunes and plenty of songs but nothing is transferring to my phone. Help please???
Posted on Feb 04, 2008
I was playing music on my juke and when i plugged it into my computer it froze and stopped working im so scared that its broken. any help?! IM me on aim at: get FISTED hoe x
please its an emergancy
Posted on Aug 14, 2008
I need to know how to change my ipod back from auto sync to manualfor 8g ipod nano 4th generation
On Mac or PC, it's the same... This is a preference setting in iTunes.
Open iTunes software, from the left top menu called iTunes, drop down to "preferences" then choose "devices" check off where it says "prevent ipods and iphones from syncing automatically"
The other spot to make sure you are controlling the music manually is;
Plug in sync cable, your ipod shows up on left column in iTunes, at the summary tab (default view) it shows a window on your screen that has three sections: ipod model, version and on the bottom it has "options" be sure to check off "manually manage music & videos." remember you can drag songs directly onto your ipod icon. (on a Mac anyway) Good luck.
Oct 06, 2009 | Apple Audio Players & Recorders
Songs don't want to synchronize onto my device
First you need to sync device before adding songs. First plug in device, than make sure computer notices player. Than go into media player or music folder and sync device. Than you can either create a sync list from there, or you can drag songs from music folder into your player folder.
Open start menu, my computer, E,F, or G drive should have player on it. You can drag songs from music folder into this drive folder and they will be automatically added
May 06, 2009 | Philips GOGEAR SA6045 MP3 Player
Trying to sync music onto my lg dare
Instead of doing the sync music, try saving your music into your itunes account or on a flash drive. Than just plug your phone into the computer, click on settings, then tools, then USB mass storage. Open the file on your computer, than simply drag and drop your songs from the file on the computer or flash drive, into the phone's file folder. Drop it into your memory card on your phone or just in my music. (I personally recommend getting a micro SD card for the phone so you can hold more songs) good luck!
Nov 18, 2008 | LG RUMOR Cellular Phone
Samsung Juke not able to put music in!! Need help!!
I had the same problem. I just called Verizon & they had me take the battery out of my phone & then put it back in, the music is working again. I'd say try that & if it doesn't work, call them & they'll help you out! Good luck!
Oct 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
Downloading music
Oh.. If I know that mp3 player, it's a USB2 type (Where you plug it directly into your computers open USB slot).
I could list alot of sites where you can buy songs, but if you have some on your computer, It's just a drag-and-drop situation.
Running Windows XP? Drivers should automatically enable it to run from your system. Try doing the following.
Open "My Computer" after plugging the player in. If you see it, you can just grab a song from your collection and drop it straight into the player.
Also Media player might be able to sync your music, but I prefer this method... Less of a hassle.
Dec 26, 2007 | iLO MP3 Player
Gpx mp3 player downloads
you have to get music on to your windows media player and plug in your mp3 player and create your sync list for what songs you want on your mp3 player and it downloads itself in about i minute per song
Dec 25, 2007 | GPX MW3836 MP3 Player
I-pod no worky
Drag the music you wish to transfer onto the icon.
On windows machines, open my computer, and drag the songs to the iPod name.
On Mac Machines, drag the songs to the removable media drive which will appear
Nov 30, 2007 | Audio Players & Recorders
Nokia 1100 Logo
2,486 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
