Question about System Power Supplies
Gateway fpd1950 lcd monitor two years old.
Powers on for less than one second and goes off.
My suspision is the inverter capacitors.
Not sure ones to replace,Can you help?
  • 482 Answers
Re: gateway fpd1950 lcd monitor two years old.
Check the card in the computer, it may need to be pushed back in place.
Posted on Nov 26, 2007
0 characters
3 Points
Samsung ua40d6400 power
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Mar 12, 2014 | System Power Supplies
When my computer is on the moniter is blank.
The monitor only has one cable and it is keyed to fit one way. They are always located under the top bezel. Should have roughly 20 pins and the wire will flow up into the display. If the screen is very very dim (look carefully) then your inverter board is most likely bad these run 40-120 dollars depending on model and are located along the bottom edge of the display itself. If the screen is completely black, try plugging an external monitor into your laptop (make sure you try toggling the display mode) [typically Fn + F7 or whichever says LCD or has a monitor icon.] If the external monitor works then your screen is most likely the problem and will need to be replaced. If the monitor does not work, the motherboard needs to be replaced. You will be hard pressed to find any schematics for motherboards but you could dis assembly the the laptop and easily check for descended capacitors, burns and the light though most of the time I doubt you will be able to see the damage.
Best of Luck
Jan 24, 2012 | System Power Supplies
Not sure which plugs go where on the bestec atx300 power supply for gateway computer. remopved the old powere supply, but don't know which plug goes where on the new one.
I'll assume that your old PSU is also an ATX. First, the plug that has a few dozen wires arranged in a rectangle goes into the MB. Your PSU's ATX connector may be split into 2 parts: the AT portion and a square portion with 4 wires. Together, they make an ATX plug. You'll find some tiny plugs with 2-3 wires for your onboard fans. You might find a few slightly larger flat plugs with 4 wires for old floppy drives. The rest should be the regular MOLEX plugs and slim SATA power plugs for your drives.
Aug 15, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Monitor goes on for a second then goes to black. could power supply inside the acer x233h be bad?
The back light behind the screen has fluorescent tubes that may be either bad or the inverter may have a problem. If you are not familiar with monitor repairing, it is better to have a specialist check for you.
Jun 28, 2011 | Acer System Power Supplies
My monitor (HP vs15) is flickering for about 5 seconds and then goes black. I managed to get it to turn back on and stay on, but now it is very dim.
It sounds like the LCD inverter is dying.
It would be cheapest to have it repaired but it would make the most sense to buy a new monitor.
If you have it repaired it might just be another part that dies next week.
Mar 06, 2011 | HP System Power Supplies
Gateway 500s power box when hitting test button powers both fans, but no power to hardrive, dvd, or monitor. I have replaced power supply, motherboard, and harddrive, I have nothing, but green power button...
Does the fan on the power supply run? As you say the power on switch lights up and so does the motherboard, means that the power supply is working. Monitor gets power from the socket on the power supply. Try plugging it in the wall socket. Try to unplug the main power cord from power supply to the motherboard. The one that has a broad plug at the motherboard end. Replug it and they power on the PC.
Sep 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Powers on for a few seconds then goes off
Your machine is not booting to the bios... time for a new machine/mother board
Aug 13, 2009 | E-Machines REXUS SPE-300 ATX 300W P4 Power...
My gateway FPD 1510 is just white thats all that shows up when its connected to a computer or not. i have a gateway 2000 old monitor and id like to upgrade.
Jan 29, 2009 | Gateway /ton 160W Power Supply (6500582)...
You'll need to check the PSU first, you might want to buy a PSU Tester for 24pin PSUs.
Then you might want to do a in depth examination of your motherbard circuit components by doing the following...
Look for burned/broken microresistors. You might need a magnifying glass and good lighting. Any resistor showing a little blob or browning is burned. Microresistors are those minuscule black,gray,brown or white rectangles lying all over the motherboard's traces. Check first the ones near the power supply connector and near the chips, specially one that says winbond on it, this last ones may get burned from USB overloading, from using non-self powered hubs also called passive hubs.
You may check for blown capacitors, capacitors are those standing cylinders with a plastic cover around them with numbers and letters printed in those covers. On top they are left without a cover and they are aluminum color, they may be flat or have one or more grooves runing across the top. A blown capacitor, looks different from the others because it looks a little bloated on the top, or may have spilled some sort of transparent varnish from its bottom to the motherboard or its top to other components around.
Finally you may suspect of the CPU, athlons get very warm and they can get burned too. Never start your pc without a cpu.
Jan 03, 2009 | Sunbeamtech SUNNU550-US-SV Nuuo 550 Watt...
I only have the mini tower - need appropriate cabes, cords, etc.
First, I suggest finding a monitor first as some have an 'attached' monitor cable and some don't. (No use buing a $15.00 cord you don't need) As far as a mouse goes, believe it or not, I've found the best prices for a good mouse at Home Depot and Publix Supermarkets. E-bay and always have great prices on most any cord.
All PC power cords I've ever seen are the same (about $11.00 at any Staples, CompUSA, Best Buy, etc.), They are will only fit PC's and VGA (old-style) monitors.
Any monitor should work just fine. For used I'd suggest and for a new LCD you probably can't beat (new owner's of CompUSA).
Any mouse & keyboard will work also. Good Luck!
Nov 22, 2008 | System Power Supplies
System Power Supplies Logo
186 people viewed this question
Top System Power Supplies Experts
Brian Sullivan
Brian Sullivan
Are you a System Power Supply Expert? Answer questions, earn points and help others
