Question about Electrical Supplies
What dose code 48 mean on an Onan Microquiet 4000
  • 4 Answers
I assume it is a ky spec j-l. It is a field sense fault. The controller is not sensing the field voltage. Check for broken wires or replace controller.
Posted on Aug 12, 2009
Onan 4000 won't turn over
check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
Jun 11, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 generator has no spark
If there is no spark, the ignition module may be bad, or the wiring to it. Have the module ohmed out. Also the magnetic trigger assembley that is on the rotor that sweeps past the ignition module maybe broken. If they check ok, suspect the control board
Mar 23, 2013 | Onan Microquiet 3600 & 4000 Generator
By pbarker987 on Jun 02, 2010 " " I have an onan microquiet 4000 KY. It will not start, fault code on red light indicates (35) control card failure. Before I take it to authorized onan repair is their...
Because it wont start does not indicate a control board problem It will start but it will shut down within a few seconds if it was. enail me and i will try to help you with the problem jbogilvie@hotmail.com
Jun 23, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan Microquiet 4000 starter will spin but not turn engine
bendix is actual the spring that pushes the gear back out of the ring gears engagement your issue is more likely a rusted /corrodied incline engagemnt gear a little lube will probably bring ti right back (do not us WD_40) this is not a lubricant it is an anti lubricant any light oil will do Good Luck
Oct 12, 2009 | Electrical Supplies
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
162 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
