Question about Acer Aspire 2930-4661 Notebook
My Acer Apire 4520 shut off while I was using it. Now I can't get it to turn back on! The battery if full charged, but when I push the on button it lights up but dosent stay on!!
    Problem Solver:
  • 6 Answers
If it went flat under battery power and not mains,Try removing battery completely, and then starting via mains without battery installed, and see if that fixes
Posted on Jul 14, 2009
Pc acer 4520 problem
Try to clean the Battery contacts using a pencil Eraser. Also, check if Acer has released any BIOS update or Battery check utility. Try using any other compatible battery and check if the same issue persists.
Jul 04, 2010 | Acer Aspire 4520-5582 Notebook
I have an Acer Aspire 4520 and the batter will not stay charged and it keeps shutting down even though I have it plugged in. Please help.
Hi there, please perform power drain first. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in, plug in the power adapater then turn on the computer. If same issue will occur then you need to replace your battery.
May 16, 2010 | Computers & Internet
Acer aspire 4520 does not power up despite fully charged battery and wall adapter turned on. power light blinks for a moment and all other indicators turn on and immediately go off. What could be the...
Remove ur battery & clean it with water and put it in to ur laptop then press 5 minutes ur power button Then ur laptop get started .
Note : Wash ur battery with clean water .
Mar 26, 2010 | Acer Aspire 4520 Notebook PC
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
I was using my Acer 4520 laptop, when it just turned off. It didn't shut down, just turned straight off. When I tried to turn it back on, the power button light, caps/num lights flash, the nothing. When...
When there is a sudden drop off like that it may be two reasons....first the charger died and is not putting out the correct voltage to run and charge the laptop, the battery may be wesk and would not last long enough to signal an alarm....or the ventilation grills, ports and van openings are clogged with dirt, dust and debris and you need to get a few cans of compressed air to blow all these openings out to clear up the heatsink fans. If this laptop has been run and has overheated, just realize that there may be irrepairable damage to the processor or mainboard.
Oct 14, 2009 | Acer Aspire 4520-5582 Notebook
Acer aspire laptop suddenly shut off and cannot turn back on
try it without the battery on the laptop. if it boots and stays on, put the battery back on and see what happens. If the problem persists, replace the battery. Acer will replace it free if you are still in warranty
Aug 09, 2009 | Acer Aspire 2930-4661 Notebook
Acer 4520 Power up for 1 second and turns off
Can you hear the system fan running? If the fan fails, the PC shuts down itself to protect the processor from FRYING.
Apr 14, 2009 | Acer Aspire 4520-5582 Notebook
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Acer Aspire 2930-4661 Notebook Logo
166 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
