Question about Garden
How do you replace the head on a echo weed wacker?
boscia
  • 163 Answers
SOURCE: weed wacker
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 28, 2008
trippssmengi
  • 76 Answers
SOURCE: istuctions for fuel line installation on weed wacker
The esiest way to figure it out is to take the line with the filter and put it on one nipple then push on the primer a few times and see if fuel comes out of the other, if no fuel then switch the line over to the other. But if im not mistaken the filter will go to the bottom.
Posted on Jan 09, 2009
  • 420 Answers
SOURCE: I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
Posted on May 14, 2009
  • 59 Answers
SOURCE: ball will not prime
you can check the filter in the tank just blow the filter out if that don't work check the lines going to the bulb if you have change the bulb out change the lines around
Posted on Jun 27, 2009
#1 Taper
  • 1040 Answers
SOURCE: How to change the string
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
Replace head on toro model #51954 curved shaft trimmers
https://video.search.yahoo.com/yhs/search;_ylt=AwrTcdIyalFXg.QAUmAnnIlQ;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=Toro+Model+51954+Weed+Trimmer+Owner+Manual&fr=ytff1-msgr&hspart=mozilla&hsimp=yhs-006
Jun 01, 2016 | Toro Garden
How to remove old head and replace with new weed warrior head.
my inlaw invented that weed wacker an opted never to use hard blades like that its veryyyy dangerous to all concerned
i use square nylon cord its just as good an safer too youll only bleed a little
other wise
youll put ur eye out.
May 09, 2015 | Garden
I can't prime my carburator on my Echo GT200r weed wacker?
clean your fuel filter and then clean your carb and replace diaphram and needle and make sure hoses are good while you are at it, the methanol causes needle and diaphram to get stiff and gum up not letting fuel into carb when primed, replace your primer blb while at it
Sep 17, 2011 | ECHO, Inc. PB-251C Handheld Blower
I need a replacement head for my 25cc crafstman weedwacker gas line trimmer. I need the whole piece that screws into the bottom of the weed wacker. It is the whole part that spins when the wacker is...
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Jun 28, 2010 | Craftsman 25cc Gas Line Trimmer
I have a craftsman pro series gas weed wacker and I need to know how to change the head to put a universal cutting attachment on
Very easy. There is usualy only one nut to undo.
You need to grip the head somehow, to stop it turning, and simply undo the nut with a suitable socket wrench. From my experience, most of the nuts on weed wackers are left hand thread, so to undo the nut, turn it clockwise.
Jun 14, 2010 | Garden
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Ball will not prime
Jun 27, 2009 | Echo Rapid Loader, Trimmer Head
Garden Logo
202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
