FixYa.com
Tags:
Neovo SX-17A 17
Screen Goes Black After Monitor is on for a while. (by 2 users)
posted by techdaddy on Nov 16, 2007
The picture goes black after the monitor is on for a while. It starts with an intermitent dimming and then it will eventually go black. If I turn it off for a while and then turn it back on it will be ok for a little bit but always ends up doing the same thing. Mine is a S-17a not an SX-17a.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by btillotson, posted on Mar 03, 2008
My problem is the same, bur mine is a laptop, so what do i do?
btillotson@triad.rr.com
Best Solution
posted on Nov 16, 2007
Helpful (85)
ntg1976
Rank:Guru Guru
Rating: 88%, 103 votes
Bad CCFLs in your LCD. CCFL stands for Cold cathode fluorescent lamps. These are the lamps that provide backlight for the LCD Monitor. These lamps do not last forever, and are a very common part to go bad. The circuit that provides the power for the CCFL is called the inverter, it might be going bad, but I still think it is the CCFL. Only trained techs should try and replace a CCFL or fix an Inverter. CCFLs do contain mercury, but only small amounts.
http://en.wikipedia.org/wiki/Cold_cathode
My advice, get a new LCD monitor and sell your bad one on ebay.
Rating Locked! (?) techdaddy has rated this solution as Helpful
Can you Help with these Monitors problems?
Monitors
screen on monitor very dark
Do not know how to adjust my... Answer This...
Monitors
Faulty backlights
What can I do to repair my... Answer This...
Monitors
off/on switch
When computer has been off and... Answer This...
Monitors
BENQ FP937s problem
Hi, I have exactly the same... Answer This...
Monitors
icemaker
i emptied the ice bucket and... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
