Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Water leakage from the door
I have side by side refrig.
I have water leakage on bottom of the door. It is collect water on bottom of freezer & leakage start from door.
  • Anonymous Mar 12, 2014
    IT HAVE WATER INSIDE AGAIN AND AGAIN
  • Whirlpool Master
  • 528 Answers
Your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is
clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
Posted on Jan 03, 2010
Ice collects in the bottom of the freezer not allowing door to shut
BA Baker... hello,
Ice collecting on the bottom of the freezer.. is not such a terrible thing...
(Probably means the defrost is working... (merely not EXITING)).
New refrig or unfamiliar refrig could cause deeper analysis...
but if ...
If this is not a new device... and has been happily tending to it's own needs (evaporating well) for a while (months would be re-assuring)...
Then you are MOST probably looking at a clogged evaporator drain... (usually easily fixed by negotiating "WARM" (not hot) through the bottom vents slots of your freezer section.
Looking under your Refrigerator/Freezer... or consulting your owners manual... Locate your defrost "catch" pan...
It should NOT be dusty...
(easily tested: clean paper in tray...
Still clean tomorrow = clogged drain (pan is watered daily).
Close inspection should reveal a tube descending into it.... This is where you will watch for your patiently applied doses of warm water to appear... (near immediate).
It may take several doses... because ice can also have formed over the drain... Be persistent... You will be proud.
Please comment me back... I really like REFRIGERATORS/Frzrs...
few appliances tend to themselves so well (adorable).
Samsung RF4287HABP User Manual
Apr 17, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
The bottom of the freezer is filled with frozen water. Also, there is an occasional water leakage found on the floor at the front side below the freezer door. Do you have any advise on how can I find the...
This can be the drain of the auto defrosted water that is overflowing from the collection tank. This is normally located at the bottom of the fridge and a little above the compressor in some cases.
So you will need to move the fridge forward to check on the bottom side of the back of the fridge.
The water can be drained out of the tank and reset.
Jun 16, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Drinking water from refrigerator stopped dispensing immediately
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
May 29, 2010 | GE GSS20IEP Side by Side Refrigerator
How do i take freezer door off a side by side frig that has water/ice options
usally a quick disconnect block for wireing harness on top freezer hing. There will be a water supply tube going up through bottom freezer hinge with a disconnect union fitting close by usally under refrig behind toe grill. once these are disconnected you can then take top hinge off of main part of refrig. by taking screws off on top of upper freezer hinge. you then should be able to lift door off by lifting up on door and water line should slide up and through the bottom hinge.
Feb 27, 2010 | Kenmore Refrigerators
Icemaker works fine but no water at door. Have water at bottom of door at quick connect but not at dispenser.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . There is also , a dispenser heater , pt . # WR49X10173 , which comes with instructions , to keep this grom happening again .
Nov 26, 2009 | Hotpoint HSS25GFP Side by Side...
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
115 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
