Question about KitchenAid K-Series 24" Tall Tub Built-In Dishwasher - Stainless-Steel
Kitchenaid dishwasher KUDK03ITBL burning hose or something smell.
I purchased the Kitchenaid dishwasher KUDK03ITBL in May and every time I run it, it smells like burning hoses or something. I had a service guy check it, and he couldn't find anything that would be causing the odor. When he opened the panel on the door, the smell was strong inside of the door but he couldn't find the source. He said it was safe to run and it wouldn't burn the house down. But the smell is offensive!! A cross between tarring a roof and a burning hose in your car! What can be done? The service guy suggested using dishwasher magic...I did and it didn't do anything.
frankgilbert
  • 613 Answers
SOURCE: My dishwasher emits a dead animal smell
This vent that you are describing is to allow air to flow in for the heat/dry cycle. Some times little creatures want to "mark" their territory by "spraying". Spray some type of cleaner like ammonia into it and **** it out with vacuum a few times. Most likely will have to flush it out quite a bit if I am right about the air flow which that is all it can be. There could be a creature that got in that vent. Is there a pice of screen that blocks it? Can you adhere one to it. I hope this is what you are describing to me. Let me know if it is not and I will research it more and thanks for using FixYa.
Posted on Jan 14, 2011
  • 1314 Answers
SOURCE: Microwave emits a burning smell when on
there is a transformer dont use it and get it serviced
Posted on Dec 29, 2007
reddyanantha
  • 205 Answers
SOURCE: dishwasher and everything run in it smells like mothballs
there will be some loose conections,the heating coil might be defective and please check if there is any wire damage undrneath the machine.if yes rectify it then provide a rat mesh.
Posted on Jul 26, 2009
garing
  • 998 Answers
SOURCE: kitchenaid (KUDM01TJWH0)
wires where thy bend at bottom of door and heating element....water in motor
Posted on Aug 14, 2009
  • 8404 Answers
SOURCE: Nasty Smell!
There is a product at the grocery store in the detergent area that will take care of this ... find it near the dishwasher products.
Posted on Apr 23, 2010
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
Kud101flss2 control panel burnt. ran the dishwasher and smelled a burning stench. Took off front door panel and found that one set of wires in melted with melting to the control panel. Is this something we...
Check out this website,kitchenaidfire.com.Many people have had fires,myself included.Fortunately we were at home at the time.We never run it unless we are home and domnstairs.Kitchen Aid should be ashamed of themselves for not addressing this problem.Please please tell anyone you know that has one of these units to beware.Thank-you.
Sep 28, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
We have a KitchenAid KUDIO1ILBL2 built in dishwasher that came with our home. First of all the bottom dish rack is falling apart and we'd like to replace it. Also when we wash something strong...
The part number for the lower rack is 8519681 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
As far as cleaning the filter this tip i wrote covers how to clean that pump asm.
http://www.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
In addation to cleaning the filter as regular maintiance a cup of white vinegar in cup in the upper rack and run the dishwasher on a normal cycle helps to clean build up in the tub.
GENE
Sep 11, 2011 | KitchenAid Dishwashers
Burning smell
I have the same problem. Never could get a resolution from Kitchenaid, however, we avoid the burning smell by using the 'energy saving' dry cycle. Have you tried that?
Feb 20, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwasher and everything run in it smells like mothballs
Jun 23, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Kenmore Elite Dishwasher model 16264 electrical fire
I contacted my lawyer who advised that I file a Civil Complaint against Sears so that is what I have done.
Feb 18, 2009 | Kenmore 24 in. 16264 Built-in Dishwasher
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
KitchenAid K-Series 24" Tall Tub Built-In Dishwasher - Stainless-Steel Logo
182 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
