Question about Saniflo 013/005/007 Sanibest Toilet with Grinder Series Pump in White Elong
Shower tray is low and fills before saniflow kicks in cant alter height of tray
    Scholar:
  • Saniflo Expert
  • 115 Answers
Most of the Saniflo products that handle a shower, need the shower base to be raised roughly 8" to 9" above floor level. It must be from the top of the shower drain to floor level.
Posted on Jul 27, 2010
  • 38 Answers
See if you can adjust the highth of the saniflow,to make it kick on sooner. goodluck.
Posted on Jul 24, 2009
  • andrew pikett May 29, 2012
    to solve this you need a small vacuam pump which works on sensors attatched to water pipe the ones we fit are from whale pumps contact them they will help you
When the shower head is in the holding pole it does not work. But if we take the shower head out and hold it down low, it works okay. Any idea what theproblem could be?
you do not have the water presher for the shower head at that the height you have it you may have to get a water pump from b&q or ebay
Aug 10, 2014 | Home
Local authority state saniflow may choke at rainwater trap and will not accept saniflow going into rainwater drain
Your description sounds like plumbing from before bacteria was discovered. The output from a Saniflo macerator should be sent to a foul drain or cesspit and not a rainwater drain.
Some authorities allow local rainwater runoff into foul drains but this situation is gradually being designed out.
Could be your Saniflo installation didn't meet building regulations when it was installed. The fact it has been working fine for 2 years doesn't count for anything if it doesn't.
Feb 03, 2018 | Saniflo Plumbing
Install plastic (fibreglass)shower floor tray. Do
no, they are designed to require no support. You may use small columns of expansion foam for added strength, but do not fill entire space with foam as it will raise the whole floor upon expansion.
Sep 22, 2010 | Home
Saniflow plus works allright for w.c but will not work for shower
Thanks for the clarification - This rules out power supply to the unit, motors/pump and points more towards why the water would be pumped from the WC flush and not the basins ...
1. The Saniflo range of macerators have a pressure switch that engages when the water pressure inside the unit activates a microswitch that is encased in a waterproof container. It is possible that the water pressure from the shower and basins is not great enough to activate the internal switch.
So, I would propose two checks
a) If the unit previously worked for the shower and basins something has changed and it is most likely to be gunk inside the unit causing the switch to be less sensitive and only activate on the high pressure that the WC would provide. The fix would be to open up the unit and clean it - please let me know if you need info on how to do this
b) If this is a new install and the shower and basins never worked, you should check the fall in the pipework into the Saniflo is sufficient (should be 1 in 70 from memory - full install instructions are available from the Saniflo website)
c) It could be that if the unit has been in for a long time with a large number of operations that the microswitch is starting to fail and is not as sensitive as it once was (quite unlikely) - but always a possibility!
Replacement microswitches are freely available online and you should also be able to get the exact match spares from Saniflo
If this helps please leave feedback - if not please let me know and I'll try and help some more!
Good Luck :)
Feb 05, 2010 | Saniflo Sanibest Grinder Pump Only 013
Im fitting a 1200 x 800 shower tray but having problems getting old one out same size,its in an en-suite, tray just a bit longer than room, dont want to break tiles thats in cant replace them any ideas
well if the old one wont come out,,, then the new one wont go in,,,as its the same size,,, looks like you will need to risk them tiles to me, even if you cut the old one out, you cant cut the new one back in can you?
so its back to them tiles, go on, risk it!!!
Oct 23, 2009 | Dreamline SHOWER ENCLOSURE TRAY Right...
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Open Questions:
Saniflo 013/005/007 Sanibest Toilet with Grinder Series Pump in White Elong Logo
559 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
