Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Log File I have set up scanning to a SMB for our C252 and it was working fine but all of a sudden it isn't. I get a Check Log File at the end of the scan. Where or how can I access this log file to see what the problem is? Thanks.
  • Anonymous Nov 17, 2008
    I am having the exact same issue and have for a bit now. The job log just says that there was an error and it was deleted, not why or anything else.
    To make it worse... Sometimes (very occasionally) it will work fine. Then within a day it again stops working.
  • 214 Answers
What it says in job history ? job done or not what error ?
Posted on Dec 31, 2007
Scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Device does not recognize delivery server
this device does not support scan router v2 lite.
your best bet would be to set up using SMB scan to folder.
set up is pretty straight forward create a folder on the root of C: ie C:scans
share the folder with full permissions, simple file sharing has to be turned off!!
then go into the device web page using the IP address ie:
go to configuration and smb create a user name ie: bill then point the device to the computer you created the folder on, ie: bill's pc/c:scans
save the configuration log out of the web utility reboot the device and you should have succesfully created an smb folder share.
if this resolves or answers your query please rate me accordingly
good luck and thanks
Aug 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Jun 01, 2009 | Konica Minolta bizhub C250 All-In-One...
We have set up a scan on a C352 using SMB and scanning to a shared folder on our file server. The scan included user name and password with authority to write to that folder. We get an error that the job...
Check the log/details.
It will clarify if it is a server connect error or a log-in one.
It will give you the details as to where the function is falting.
It may be as simple as entering the file path correctly.
Jan 19, 2009 | Konica Minolta bizhub C250 All-In-One...
SMB Scanning to a Macintosh
I don't know if SMB for a Mac is supported on Bizhubs. I know it works with Microsoft workgroups. The only other way to get around it is to scan to e-mail. Then retrieve the e-mail from a Mac.
Oct 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Scan to smb
Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
May 19, 2008 | Xerox WorkCentre M128 Copier
SMB settings error.
if i remember right, the settings should be:
server: / or server name
folder: Sbssvr1\Scans\SCANS
and if still not working, try give some user name and pwd, some networks require this.
Apr 24, 2008 | Konica Minolta bizhub C250 All-In-One...
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
668 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
