Question about RCA HD50LPW42 50" Rear Projection HDTV
HD50LPW42 making noise near lamp
I have a HD50LPW42 and the lamp went out. I replaced it and the sound and picture are fine but there is still a humming or buzzing noise coming from near the lamp. It does not seem to be the fans and they are working when they are suppose too.Does the color wheel have some kind of bearing on it?
  • cajaranch Jul 13, 2009
    Will it make noises but still have a good picture?
  • 583 Answers
Colour wheel doesnot have bearing.but if its faulty it makes some gearing noise or click click noise.check out.
Posted on Jul 13, 2009
  • livetech Jul 13, 2009
    yes this is the starting of getting the colour whell faulty.also if the position of wheel is got moved while replacing bulb.this can create noise.reset the wheel again and check out.
Where is the whell ?/
Posted on Jul 26, 2009
I have a RCA HD50LPW42, the tv stopped showing the picture awhile back but the sound continued when the tv was turned on. Now the sound has gone out too. When I turn the tv on the green power light blinks...
You may have two problems with your TV. This TV has a history of a color wheel issue, was making grinding noise? Have you ever changed the lamp?
It may be a bad color wheel and the lamp, you may want to do a visual inspection.
It is easy to replace the lamp but more likely the color wheel is the problem.
The part# for the color wheel is 212184, the part# for the lamp is 260962
Best of luck
Nour Sabre
www.aaatvservice.com
Nov 16, 2011 | RCA HD50LPW42 50" Rear Projection HDTV
Rca hd50lpw42 has sound but no picture. i have replaced the broken bulb but still no picture
If you replaced it with a brand new lamp then your light engine is provably bad. The only order thing you can check is your color wheel. www.interliquidparts.com
Jun 13, 2011 | Televison & Video
RCA HD50LPW42 dlp, does not turn on
If capacitors are swollen,vented or puffed up on top replace them .You may just need to replace your Lamp.CK all fans make sure they are running. Mats Electronics has Best Price for Lamps 1-800-628-1118
Let me know if you need more help.
Mar 23, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
RCA 61" TV (HD61LPW165) Lamp Fan making noise
Here ya go:
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=662661
Much better longer life part. 80x80x25 mm 35 cfm with rotor lock wire. Connect the yellow to the blue wire on the tv, black to black red to red.
Sep 25, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
No picture, installed new lamp but it is not getting voltage
no can't check power out to high it is about 15,000 volts out put all you can do is is listen to ballast and see if you here a spark if not bad make sure you have the light door switch bypassed.
Sep 28, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Green light On Off
You should listen for a strike noise at the lamp or ballast area, 1 strike for each cycle. A weak lamp will take more strikes to start, until one day it never starts.
Feb 05, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Sawing noise
Sounds like the same problem I encountered with my TV might be
ballast.
Dec 31, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
RCA HD50LPW42 50" Rear Projection HDTV Logo
552 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
