Question about RCA D52W19 52" Rear Projection Television
Power problem My TV will turn on for about 3 sec.(there is no pic and no sound) then it powers down. Anybody have any suggestions? Thanks
  • 583 Answers
It’s the problem of main power supply circuit board.on the circuit board any of the capacitor or ic is gone faulty.so when you turn the tv ON the current passess through the board but cannot pass from that particular faulty part and the board gets overheated and tv turns off automatically.as you mentioned the tv turns on for some seconds.it will not be a major costly .but the board needs reparing to solve this problem.
Thanks.
Posted on Jul 13, 2009
3yrs old LG SMART LED TV 60LS5750-UB. TURN ON THE TV AFTER 3 MINS THE PIC TURN INTO HORIZONTAL BUT HAS A SOUND ON IT. WHAT SEEMS TO BE THE PROBLEM IS THAT T-CON BOARB OR LED DRIVER?
What is the brand name and type of the TV? Without these details, how can one post a solution to your problem? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Televison & Video
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
I have a viz e550vl good pic no sound at all no matter what i do, tried unplug tv hold power button for 10 sec. any help please thanks
have you been already check the speaker does it good?. if ok, tried to hooked up a powered pc speaker at the audio output jack of the tv. turn on, if you can get sound there the cause it would be bad amplifier circuit but if you can not get sound from there you have bad sound processor at the board.
Oct 02, 2012 | Vizio E550VL 55 in. LCD HDTV
Rca d52w23 tv power light comes on then off after about 3 sec. this happens 3 times without pic or sound, then tv stays off
vvghostvv,
You could literally have anything wrong with your unit. RCA standard procedure is to try to start 3 times when there is a fault then lock the unit out. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting process as well as tell you where to get any parts you may need.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 08, 2011 | RCA D52W23 52" HDTV CRT TV
Tv turns off after playing 15-20 minutes, then it will shut down more often. the timer/pic. off button flashes six times. thank You.
6 times power/ standby light blink error shows problem of back light inverter board in your Sony KDL-37M4000 tv as per mentioned in related service manual.
Check back light inverter board to fix the issue.
Thanks.
Jun 17, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Pic freezes, goes dark w/sound then back on
By what you have said your color wheel can cause this when it stops running .Pull back off and watch what is happening when you turn set on.
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
135 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
