Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
How do I hook up the upholstery tool to my steamvac?
VacuumRepair
  • 438 Answers
SOURCE: i want to use upholstery cleaning tool and do not
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Posted on Jun 15, 2010
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
The original problem was, How do I attach the upholstery attachment to the cleaner. I see where the water connection is, but not where to attach the hose part.,
The solution to attaching the upholstery attachment to the Hoover Steam Vac cleaner was excellent for steps 1 and 2. However, in step 3, I can not simply slide the upholstery attachment straight down. It gets stuck and does not connect to the bottom connector and is stuck in midair. It seems like I am doing something wrong. My Hoover model steam vac model number is F5900-900.
The solution given in steps 1,2, and 3 where I have a problem with step 3 is as follows;
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Feb 16, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
  • 7 Answers
SOURCE: Instructions on how to put attachments on hoover
Remove solution tank.
Remove recovery tank and lay cleaner flat on floor. Remove lid,
Now, remove front panel from recovery tank by sliding it straight up.
Take your hose and slide the U-shaped end (converter) into the place where you removed the panel. Slide halfway down opening until it is firmly in place.
2nd step: You should have a tube with a "plug" on it hanging from the converter end. Open door on hoodl abeled "Stair upholstery/Cleaning Connection". Extend black tabs by pulling tan collar toward tube. Press connector collar down firmly to ensure that it is fully connnected.
It's sort of like a childproofed plug and socket. Pull back on the collar and push in the olug. Not hard at all once you've done it the first time.
Make sure you put the lid on the recovery tank correctly so you have suction. Attach whatever brush you want to use on the other end until the tab locks into place.
Sometimes you have to bleed the air from the line by turning on the cleeaner and letting it **** against your hand or hard surface for 15 seconds before its ready to use. This gets the solution to flow to the tool.
Posted on Aug 06, 2009
SOURCE: no instructions on how to attach the upholstery
I downloaded a free manual.
Posted on Dec 30, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How do I hook up the upholstery cleaning attachment
Right, how to hook up the upholstery cleaning so the water will drain?
Sep 20, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How do i hook up the upholstery attachment to the main unit
See http://www.hoover.com/CustomerService/Manuals/Default.aspx to lookup the manual for your model.
Feb 26, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do I get the handtool to work on my Hoover Steamvac carpet cleaner?
Please reference page 11-12 on this manual:
http://www.hoover.com/pdfs/manuals/F6039900.pdf
The tools are plugged on to the end of the hose, and the hose supplies water and vacuum to the tool.
Oct 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hook up upholstery hose, lost manual F5915-500 steam vac
Yes, I did figure that out. That would be 9.99 first, please and I would be more than glad to post the solution.
Feb 07, 2009 | Hoover V1 SteamVac SpinScrub Vacuum
NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Dec 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How do you apply attatchment for upholstery cleaner
If can only go on one way so it will lock. If it doesn't, then something is broken either the attachment or the hose end where it hooks to.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
441 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
