Question about Canon FAXPHONE L170 Plain Paper Laser
The Canon L170 will not grab the paper.
How do you replace the paper separation guide on the Canon L170? We have a new separation guide but are not sure how to install it. Are there stops to access the area or do we remove the two screws on the bottom side of the top?
  • 318 Answers
Yes,remove the 2 screws at the bottom of the docfeeder,then the lower side of the dockfeeder will come apart.Remove the tention spring of the separation and lift the separation upwarts,then you can install the new separation.
Posted on Jul 14, 2009
"supply Rec Paper Cassette" canon L170
Tip up L170 and ensure paper detect flag is not broken or dislodged
Dec 06, 2012 | Canon Faxphone L170 Monochrome Laser Fax...
Volume on Canon Faxphone L170
By pressing the menu button left of the LCD display,scroll to usersettings press ok.Scroll to volume settings press ok and change volume levels there.
Dec 11, 2009 | Canon FAXPHONE L170 Plain Paper Laser
We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
Dec 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Would like to receive legal faxes through mpf on my canon l170
Starting on page 4-8 and continuing thru step 3 on page 4-9 will allow you to setup the mp feeder for legal size paper on your Faxphone L170.
http://gdlp01.c-wss.com/gds/0900006140/FAXPHONE_L170_Basic_Guide_EN.pdf
Oct 26, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Change the time date and year
This is a link to Canon FaxPhone L170 Basic Settings Guide. Look on page 3-4 in Registering Information section.
Oct 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Where is the fuser on a canon L170? Can I change
It'slocated on the rear of the unit and is a stinker to remove. All of the external covers must be removed and the frame must be separated to remove it. Lots of piecews and parts. Not for beginners.
Jun 30, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Fax will not grab paper
Ther is a separation pad that developes a divot caused by the feed roller. Simple fix. order a new separation pad. It's located under the top cover. Just move slowly and identify the latches that hold the cover down. Don't force anything.
Another possibilty. If a document was forcably pull out of the document area the "White paper bar above the scanner glass might have been jerked out of it's normal position causing a blockage in the path. Investigate this possibility before ordering parts.
Jun 15, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Canon L170 will not feed paper in for faxes or copies.
as the rollers move with the help of the side gears .which r made up of plastic and that gears r worn out or got cracked as due to this it pulls the paper but the gears are cracked so it does not pulls the paper further and it hangs in between.as to resove this the gears needs to be cleaned and checked if the problem not solved the gears neeeds to be replaced. thanks.
Jan 27, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Canon mx700 printer
Using a q-tip clean the rollers with rubbing alcohol.
Try different paper. The fact that it grabs more than one page means the paper or rollers are dirty.
Mar 05, 2008 | Canon MX700 Office All-In-One InkJet...
Canon FAXPHONE L170 Plain Paper Laser Logo
311 people viewed this question
old marine
old marine
