This sounds like a resolution problem. Change the resolution in Windows to something that is a little wider and your picture will probably go back to normal.
There also may be a "reset" button on the monitor. If so, push it.
Windows Vista®
1 Right-click an open area of the desktop.
2 Click Personalize. The Personalize appearance and sounds window
appears.
3 Click Display Settings.
4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51
5 In the Display Settings window, move the Resolution slider bar to the left
or right to select a screen resolution that matches the native resolution of
the external LCD monitor.
6 Click OK.
Windows®
XP
2 Click Properties. The Display Properties window appears.
3 Select the Settings tab.
4 Select the external LCD monitor in the Display drop-down menu.
5 Under the Screen resolution section, move the slide bar to the left or right
to select a screen resolution that matches the native resolution of the
6 Click OK.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD By dmorrow54 on Nov 13, 2007 Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me. Add a comment
c7carl
5 minutes ago
WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use. Comment:
to reset the D2x to its default settings:
1. press the Menu button.
2. scroll to the Custom Settings Menu (the pencil icon in the left column).
3. press the right side of the multi-selector to move the highlight into the menu.
4. scroll to Menu Reset.
5. press the right side of the multi-selector to move into the Reset CSM Menu window.
6. scroll to Yes.
7. press the right side of the multi-selector to reset the camera to its default settings.
I pressed the menu button and didn't see any default button
