Question about Maytag MDB7100AWB Dishwasher
No Power, No Lights on MDB7100AWQ
I went to start the dishwasher, I pushed the button to start a wash cycle, and nothing happened. I can't get any of the lights on the control panel to come on. The unit is hardwired. The circuit breaker wasn't tripped, but we flipped it on and off anyway ... but that didn't do anything.
  • 1 more comment
  • Terry Hufstetler
    Terry Hufstetler Oct 18, 2011
    Mine is doing the same thing...did you find out what was wrong and how much did it cost?
    Thanks for any help.
  • Valerie Walker Oct 18, 2011
    We had a repairman out and they had to replace some part which cost about $200 ... less than buying a whole new dishwasher. Our dishwasher was about 8 years old at the time, and two years later it's still running strong, so I think we made the right choice on repair.
  • desirae May 03, 2013
    What part did he replace?
The repairman (friend of mine) came out and worked on it for about 10 mins...the whole front panel burned out hence no power...he will call me today with how much this new panel will cost me...thank goodness he is a friend. Since yours was 200.00 it might be that much.
Posted on Oct 21, 2011
  • 6,784 Answers
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jul 13, 2009
Kenmore ultra wash dishwasher only half of the lights light up when pressed when press start nothing happens
Do you mean only half of the lights that you push stay on ? If I try to push in too many buttons at the same time, or the cycles I push don't function together, that some of them stay off because they aren't programmed to run at the same time. And the machine is set up to not allow you to expect it to do all the functions during the same cycle.
Jul 19, 2014 | Kenmore 665
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 02, 2012 | Kenmore Dishwashers
Dishwasher lights up when Normal Wash is pushed, also heat dry - but when start is pushed all three lights (Normal wash, heat dry and washing) blink then go out and nothing happens. This occurred after a 2...
What is the make and model so we can better assist you? In the mean time shut power off to the unit briefly, then turn it back on and try a normal cycle. Will be watching for a make and model here.
Jan 20, 2010 | Dishwashers
Wash cycle will not start
it is likely that you have a water leak causing the dishwasher to go into flood mode. to find this out tip the dishwasher sideways and see if water seeps out of the base if it does it will need to be sourced.
Mar 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Maytag MDB7100AWB Dishwasher Logo
787 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
