Question about Nokia E71 Smartphone
After updating software from nokia pc suite, E71 asks for code-lock ? On rebooting phone asks for sim-code , then security code [no problem] then it asks for lock code ? No idea what this can be, can you help. thanx alan
    President:
  • 2,004 Answers
Please the default code for nokia is 12345 except you have changed it then you can generate a master reset code on http://www.nokiamastercode.com by entering your imei number there.
Good luck.
Posted on Jul 14, 2009
  • Onifade Adewunmi
    Onifade Adewunmi Jul 14, 2009
    Remember to rate my solution.
"I forgot my 1202 security "I forgot my 1202 security code imei no 358264035618883 plzzzzzzzzz help me..
After several wrong attempts it'll ask for PUK code
PUK code you will get from your service provider
call your service/sim provider customer care asking for PUK code
it will remove your blockage
otherwise connect your phone to any pc via nokia suite and from options update your phone software
it work for nokia
Jan 23, 2014 | Cell Phones
I'm using a nokia e71,done a software update then it asks me for a lock code which i never set,tried a default 12345 but it doesn't accept it
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
May 31, 2011 | Nokia E71 Smartphone
I have a nokia 5310. When I insert my Airtel or BSNL sim ( my old sim which i have used with this phone for the past two years ) it works fine, but when I use my vodafone or aircel sim ( which are my new...
hi
you are installed a security code when you are using your old sim cards
so if you wont to install a new sim card you have to know your security code
other wise
1) insert your old sim card
2) switch on the phone and back up all data
3) Connect your phone to pc using Nokia PC Suite and Data cable
4) make sure about your data
5) Download the Nokia Software updater
6) Update your phone software or reinstall if you have already latest software
if any doubt replay me
Link for nokia Software updater
http://www.nokia.co.in/support/product_support/phone-software-update
May 27, 2011 | Nokia 5310 Cellular Phone
I forgot my security code and wene am restart my mobile he ask me the security code please help me
If it's asking security code.....Default code will be 12345 try the following *You will get the master code from http://www.nokialockcode.com/mastercode.php
or mobile-unlocker.com/samsung-a837/rs2wp9/ and superunlockcodes.com/unlocking-services/rs12wp6
*you can flash your phone to reset the security code to 12345
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
If it's asking PIN CODE *Default code will be 0000 *Enter the any numbers 3 times and your sim will locks and asks for PUK code.Now contact network operators customer care they will provide your PUK code
Don't enter wrong PUK code 10 times.....
Thank you Don't Forget to rate Have a nice day
Jan 28, 2011 | Nokia E66 Smartphone
Is there an option in nokia pc suit to restore ur phone to factory settings ?
Hi ,friends,
You can restore the software and the hardware
Due to the amount of data it handles, a slow down in your phone may arise or a conflict in applications may occur, or worse, a total malfunction in your Nokia E71 may happen. A hard reset should be done only as a last resort as it will wipe out most data and new applications you have installed.
Just follow the link=
http://www.ehow.com/how_5823842_perform-hard-reset-nokia-e71.html
Dec 14, 2010 | Nokia E71 Smartphone
My nokia e71's display frequently goes off and fails to return even after switching it off and replacing the battery. it however still receives calls but am not able to tell who is calling.i wonder whats...
Try to hard - reset the Nokia E71. Before doing this, make sure you are backing up everything via Nokia PC Suite to your laptop/desktop.
To perform hard - reset, you can use below instructions.
Type *#7370# from the standby screen while your phone is on.
It will ask for the lock code which is 12345 unless you have previously changed it. Make sure you do this right, because if you do it too many times the wrong way you can lock up your phone.
* If your phone has software problem, then I believe the above solution will be the good fix.
* Once you complete the above procedure, download the latest update through Nokia PC Suite by selecting your phone.
Thanks,
Amar
Oct 06, 2010 | Nokia E71 Smartphone
Putting a lock code on an e71 to unlock phone
It is possible to put code on E71, You go to settings then security, you will enable the keypad security code and enable your phone code also. With these nobody can access your phone without asking for security code. Take note Phone, sim and keypad pin code must be enable. Thanks
May 13, 2010 | Nokia E71 Smartphone
Forgot security code nokia 6288
I forgot my security code for nokia 6288 plz help me if you can
353226/01/385828/1
Apr 24, 2008 | Nokia 6288 Cellular Phone
Nokia E71 Smartphone Logo
306 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
