Question about Minolta EP4000/5000 CS/PRO Copier
Minolta cs pro 5000 has touchscreen vision probs and having trouble re-connection coallter to copier
  • mrpendous Jul 13, 2009
    the touchscreen has # fpn 010 38... is that the part you mean to try and reconnect?
  • 583 Answers
There is cable from touch screen to circuit board internally.its white coloured cable.that is removable and replaceable.also you can get that cable from local electronics shop.just take the old faulty cable with you to get the exact length and size cable.but to get the cable of the touch screen the fron pannel of the unit has to be removed .this is bit tough .as the unit needs to be opened.if you have any local printer repair shop near your area get it opened there and replace the cable.the cost of the only spare cable will not be more then $7.plus the service charge of the technician.
thanks.keep updated.thank you for using fixya.please do rate the session.
Posted on Jul 14, 2009
  • Minolta Master
  • 19,396 Answers
The touchscreen problems are usually related to bad connection to LCD.
About connection problem, you need to give more details on how and to what the copier is connected, and about what kind of troubles you get.
Regards.
Posted on Jul 13, 2009
Touchscreen tidak berfungsi
Touch screen for a EP4000/5000 will be hard to find. Third party mite have one. The machine is Legacy Minolta now KonicaMinolta.
Oct 21, 2013 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE 0520 IN MINOLTA 5000 PHOTOCOPIER
C0520 - High fuser temperature
This error relates to a problem with the fuser, are more specific to a problem of temperature, to reset this error so you have to enter technical as you say and you will see an option that puts you "counter" see another option in "trouble" there looking for the error in the list, to reset press "C"
Good luck.
Apr 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
PARA ENTRAR EN EL SOFTWARE DE LA FOTOCOPIADORA MINOLTA CS PRO 5000
There is no software for the EP5000 IT CAN NOT BE CONNECTED TO A COMPUTER
Feb 08, 2011 | Minolta EP4000/5000 CS/PRO Copier
Problem c0400 for Minolta
Exposure lamp to reset open front door to your upper left remove the access cover press the trouble reset, if the code comes back replace the bright light under the big glass
Oct 31, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta cs Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
May 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Cs pro 5000 touchscreen very dim and trouble re-connecting coallter to copier
The LCD unit has a miniture tube lamp in it off to one side on the back side of it. That tube lamp is burned out. You'll have to replace it to fix it, and good luck finding one.
Jul 13, 2009 | Minolta EP4000/5000 CS/PRO Copier
Touchscreen and coalator connection
The back light on the display panel has burned out. I'm not sure if the LCD assembly is even still available for this model. Before we completely discontinued servicing this model, we couldn't get them anymore from minolta. The last one I replaced was about six months ago and I had to get the replacement part off a junked machine in the warehouse.
I thinking of buying one of these machines
The Minolta EP-5000 is a analog copier. That means that it can not be connected to a computer to print to, it is just a 50 a minute copier.. It is to old to be connected, it came out around 1996 or so..... It is naot a bad copier, it is one of there old work horse... It is a up-dated version of the EP-3050 & 4050.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
56 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
