Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
I need help hooking my pool heater up to the power. Where do I hook it up at? model esg250n serialf94pk0417
  • 139 Answers
Power input feeds into right side of heater.remove door and remove 5/16 screw that holds metal cover adjacent to input opening
Posted on Aug 12, 2009
I have a Hayward H400 that shuts off at 88 degrees. What could this be?
Is this heater standalone, or is it hooked up to an external controller? If it is standalone, it sounds like you need a water temp sensor for the heater. If its hooked up to an external controller, you likely need a 10k temp sensor. What error code does the heater display when it shuts down? And what temperature are you able to read on the heater and/or external controller?
Aug 25, 2014 | Hayward H Series Pool & Spa Heater 400k...
Pump
in of pump front to in of filter return to heater if no heater to pool return if heater out of filter to in of heater out of heater to pool return
Jun 01, 2013 | Hayward S166T Pool Filter System w1 HP...
Our pump bearings noisy, had small engine shop repair hook back up , now ce reports on heater ????
Pump bearings, hook up, CE error...not following your sequence of events here. CE error on a Hayward heater means a problem with the control board communicating with the display board. Generally it means you need a new display/bezel assembly. None of this should have anything to do with a motor repair unless at some point during all this someone grounded out line power and sent a surge thru the system in the process.
John
Sep 07, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
I've installed a intermatic t101p201 which has a heater delay circuit - but can't get power to the heater through the delay switch when i turn the switch manually on - i haven't checked yet to...
Check that your pool heater supports optional fireman's switch
Black wires on firemans switch connect to pool heater. Power to fireman switch comes from pool equipment and not the timer.
If pool equipment does not support fireman, then cap off the wires.
Fireman switch turns off heater 15-20 minutes before turning off pump.
The purpose is so pool equipment lasts longer.
You can buy the fireman's switch separately, but if this is new timer, then switch is probably good.
Open following link to identify fireman's switch and related parts for the timer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#fireman
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Intermatic HEATER DELAY SHUT OFF SWITCH...
Need to replace gas spa heater. Is there a combination gas and solar spaheater
You may actually use any pool heater with a solar water heating array. I do not however know about any that come as a package deal. You will need a solar array, a solar controller, a actuating valve to hook to the solar controller, and a new bypass assembley for the plumbing system. All of this is made by manufacturers such as : Jandy, Pentair, Raypak, Lasco, Buderus, Hayward, etc....
Feb 16, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Our pilot light on our Teledyne Laars ESG250N will light but our heater wont come on. Can anyone help me find any info on our old heater?
check pressure switch should be 24 volts on both terminals if not bad switch or plugged copper tube you can jump just to check
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Want to hook it up to my hot tub
Yes, these pool heaters are designed for use with a spa. They are made to accommodate temperatures for both a pool and a spa running off of the same heater. Check the owners manual for specific instructions.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
May 23, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
64 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
