Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Craftsman 1/2 hp garage door opener that is approx. 16 years old. I need to change the access code on the numeric key pad and have lost the paperwork with the instructions on how to do this. I want to keep the remote access the same and not mess with that. Can I get instruction on how to reprogram the numeric code?
  • jocarsb Jul 14, 2009
    I must have a different model because there is no switch inside console. The only adjustments that can be made are on the unit suspended from the garage roof that houses the motor. Those adjustments are for adjusting door speed etc. Now what? I think there is a way tor reset from the numeric pad itself.
  • 583 Answers
You will need to push the learn button,watch for flashing LED in unit then point remote to flashing LEDand press remote for 1 second then press again. Door should operate.
also click the link below and read the instructions on how to get various problem with door opener fixed: go through all the issues.it will help you understand and operate your device more better too.
http://www.aaaremotes.com/gadoopbaqbyh.html
Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 14, 2009
    Top Expert:
  • Sears Master
  • 78,936 Answers
Disconnect the garage door opener and pry off console cover, this is the console inside the garage, move the little switch at top right to "PROGRAM",( RED LIGHT SHOULD BLINK ON THE OUTSIDE KEY PAD), input a ramdom four number code into the keypad, move the the switch back from "PROGRAM" to "OPERATE" reconnect opener and try the new code, repeat as necessary.
if u want the actual instruction sheet send me your email address and i will scan it and send u a copy, also if u have a fax number i can send it there as well.
Posted on Jul 13, 2009
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
Keyless pad will not communicate with reseiver
Are you sure you purchased the right keypad? The model you should have is 139.53681
May 03, 2012 | Sears Craftsman LiftMaster Chamberlain...
How to change code on Sears keyless garage door opener keypad. Unit is approx. 10 years old - instructions tossed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Dec 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp yellow button old garage dorr opener key pad will not open door tried a new battery and tried to re program it will nit work
It sounds like your keypad has just failed. Try programming it like this if you haven't.
Nov 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't open.
The most common cause of this problem is the door sensors have been bumped and misaligned. They each have a small light that should be lit and not flickering. Tweak them until they are pointed at one another and the lights are lit.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a non-functioning keypad for my Liftmaster garage door. It's 8 years old. In the past changing the battery has remedied the problem. This time I changed the battery twice with no success. The light...
First of all, did you try recoding unit by hitting LEARN BUTTON on motor. Try that. If n/g, try a new code with a number you did not use. Example, if old code was 5834, try 2222. If it works, one of the numer from you old code is worn out. Try new code or buy new pad.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door key pad
For most openers you don't need the old code.
Just press the program button on the powerhead enter the code you want in the keypad and press enter (within 20 seconds).
Jul 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
41 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
