Question about RCA 20F511T TV
RT801 need part no. for rt801
SOURCE: TV will not power on
The MZ73L is a posistor, its basically 2 thermal resistors back to back. One is connected across the mains, the other one connects the deguassing loop to the mains. When the TV is 1st turned on the mains connected R is cold so its neighbour is cold, that allows a large surge of current into the degaussing coil. The mains connected one rapidly gets hot and heats up the other one, this increases the resistance of it and the current being dumped into the degauss coil fades away. As the 1st one is a heater it will get hot and you will see signs of heat on the PCB, BUT its still a very good place to start. The heat is normal, but if the 1st ceramic disk in it has died then you will short the mains and blow the fuse with it.
Posted on Apr 20, 2008
0 characters
1 Points
I have a Durabrand tv. Model DWT 1304A. How do I get my Dish network to work on it. What do I set my tv. and how do i do it. Thank You
I hope that you have gotten this resolved, but if not, here are some steps to get that working!! I hope this helps!
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
Becki Barned
DISH Network Customer Service
Aug 07, 2011 | Durabrand DWT1304 13" TV
I just got cable today and need the code to the remote my tv is sanyo
I assume you want the code for the service adjustments which is to hold the Menu button on the TV down then plug in the set and service menu comes up.
If you need a code for a cable box for a sanyo remote check your users manual or i need more info about the cable box.
If you need a code for the sanyo for a 3rd party remote control you need to specify the remote. Or check its users manual.,
Mar 28, 2010 | Sanyo DS27800 27" TV
I need an extention cable for a tv. Please direct
Your nearest Radio Shack should be able to help you out.
Sep 07, 2009 | Standard (CRT) Televisions
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Need codes
i have a sylvania tv with a ge universal remote control
Oct 02, 2008 | Standard (CRT) Televisions
I need the code for a celera tv
need codes for the URC-3220 remote control
Apr 21, 2008 | Quasar SP-3235 32" TV
i need help i have a emerson tv but the remote is geuniversal i need the code please
Dec 02, 2007 | Emerson TS1997 19" TV
I need the universal remote code for a celera K12B-C11 TV
Nov 05, 2007 | Standard (CRT) Televisions
You will need to acquire the service and parts manual. This will guide you to the correct part number(s) you'll want to order. Any reputable parts dealer can help you in that aspect.
What usually causes these types of problems is a failure of the device itself or a "chain reaction" sort of event, causing the visibly defective part to smoke through no fault of it's own. Be sure to check for proper voltages before condemning the wrong area. Hope this helps...Accordianman
Nov 04, 2007 | RCA 20F512T 20" TV
RCA 20F511T TV Logo
48 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
