Question about Whirlpool ACQ088 Air Conditioner
Does not cool ? - Whirlpool ACQ088 Air Conditioner
  • 355 Answers
There are 3 possiblities
  1. something obstructing the lower fan motor (or exhaust motor)
  2. bad fan capacitor
  3. or bad motor
to check any of these you will need to disassemble the unit to get to the blower. there are several screws located at various points on the plastic housing covering the unit. Once removed you should be able to check for motor obstructions visually. for checking the motor and capacitor you will need a volt/ohm meter and ideally a capacitor checker. you could try to spin start the motor while it is powered up this could be a possible sign of a bad capacitor if it will start when you do this or if the motor will spin freely while powered down and will not spin start when powered up. I know that is kind of confusing but its how they work.
regards
Posted on Jul 13, 2009
My 07 Saturn Relay shows ac off for engine protection but the gauge shows cold. The hoses feel normal. What is happening?
A/C Off For Engine Protection
Refer to Cooling System Description and Operation
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active.
This is something you need to take to a qualified repair shop .
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) or engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 maxifuse® through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation, the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 2 relay and the cooling fan relay through the high speed cooling fan relay control circuit. This energizes the cooling fan relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 maxifuse® on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Nov 20, 2016 | 2007 Saturn Relay
Wiring for cooling system ford escort zetec 1996 1.6i
Wiring for cooling system ? You mean cooling fans ? 1.6 ? This vehicle has 1.8 L or 1.9 L . This cooling system has two electric cooling fans . Three relays , cooling fan power relay , cooling fan hi speed relay an the low speed cooling fan relay. The powertrain control module controls these relays. Go here http://bbbind.com/free_tsb.html free wiring diagrams .
May 15, 2016 | Ford Cars & Trucks
Where is the cooling fan relay located
In the engine compartment fuse block. Look at positions 7 and 8. There should be a diagram under the lid.
Apr 18, 2016 | 1999 Oldsmobile Aurora
Where is the fuse for motor fan in uplander 2006?
there is 2 fuses that you have to check
one will be in the big fuse assembly in the engine bay, the other probably in the fuse assembly in the cab
If they prove ok then it is possible that the coolant temperature SENSOR is faulty and needs replacing
don't confuse it with the temperature sender which operates the temp gauge.
Aug 10, 2015 | 2006 Chevrolet Uplander
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Aug 08, 2015 | Cars & Trucks
2004 Venture Chevrolet minivan cooling fan circut
Are you talking about the radiator fan? How hot does the engine get in degrees F? Some makes and models, the radiator fan won't turn on till about 220 degrees F. Check for applicable trouble codes, see if any code that refers to the radiator fan circuit or coolant temp sensor? Some of the national brand auto stores will check codes for free.
Of course, as far as overheating in general, you have the thermostat--water pump and other possible issues. Are you losing coolant?
Dec 14, 2014 | Chevrolet Cars & Trucks
Ir400 fan numbers
II. FANS
A. Arrangement and Functions
Feeder fan
Fixing assembly heat discharge
fan 1***
fan 2 ***
Laser driver cooling fan
Laser scanner motor cooling fan 1
Laser scanner motor cooling fan 2
Cleaner heat discharge fan
System cooling fan
Reversing guide cooling fan
Low-voltage power cooling fan 1
Low-voltage power cooling fan 2
Reader cooling fan 1
Reader cooling fan 2
Drum cartridge cooling fan 1
Drum cartridge cooling fan 2
Drum cartridge cooling fan 3
DC controller PCB cooling fan
Scanner motor cooling fan
Function
Draws copy paper to the feeding
belt. Helps feeding.
Discharges heat from around the
fixing assembly.
Cools the laser driver PCB.
Cools the laser scanner motor.
• Cools the laser scanner motor.
• Insulates the drum cartridge
against heat from the fixing
assembly.
• Discharges heat from the
drum cleaning assembly and
fixing assembly.
• Discharges heat from the DC
controller PCB.
composite power supply and the
DC controller PCB.
Prevents curling of paper.
Discharges heat from the lowvoltage
power supply.
Cools the reader (image processor
PCB, laser driver PCB).
Cools the drum cartridge.
Cools the DC controller PCB.
Cools the scanner motor.
Aug 28, 2012 | Canon imageRUNNER 400S Copier
Not Cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfad
Jun 13, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Where is the switch that cuts on the cooling fans on a 2000 grand am with a 3.4 engine
The computer turns on the fan. Based on sensors from the motor.
DTC P0480 - COOLING FAN CIRCUIT
Circuit Description
The cooling fan is controlled by PCM through the fan relay based on inputs from ECT sensor, IAT sensor, A/C selector switch, A/C refrigerant pressure switch and vehicle speed sensor. PCM controls cooling fan by grounding cooling fan control circuit which turns on cooling fan relay.
The fan relay will be commanded on when ECT reaches 223°F (106°C) or greater, A/C is requested or vehicle speed is less than 38 MPH. Cooling fan relay will also be commanded on regardless of vehicle speed when a DTC is set requesting cooling fan to be on, ECT is 304°F (151°C) or greater, or A/C refrigerant pressure is high. Cooling fan may also be commanded on when engine is not running, on certain conditions.
Conditions for setting DTC:
Battery voltage greater than 9.5 volts.
Cooling fan fault line detects a malfunction for 6 seconds.
1. Check cooling system. Ensure coolant level and belt tension are correct. Adjust/repair as necessary. After repairs, go to step 23). If no adjustment or repairs were required, go to next step.
2. Turn ignition on, with engine off. Using scan tool, check if cooling fan is operating with ECT at less than 209°F (98°C). If cooling fan is off, go to next step. If cooling fan is on, go to step 4).
3. Command cooling fan relay on. If cooling fan operates, go to step 23). If cooling fan does not operate, go to step 5).
4. Turn ignition off. Disconnect PCM harness connector. If cooling fan turns off, go to step 23). If cooling fan does not turn off, go to step 6).
5. Disconnect cooling fan relay harness connector. Using a test light connected to ground, probe battery feed circuits in relay harness connector. If test light illuminates on both terminals, go to step 7). If test light does not illuminate on both terminals, go to step icon_cool.gif.
6. Disconnect cooling fan relay harness connector. With test light connected to ground, probe battery feed circuit in relay harness connector. If test light illuminates, go to step 9). If test light does not illuminate, go to step 10).
7. Connect a jumper wire between cooling fan relay battery feed and cooling fan battery feed circuit. If cooling fan operates, go to step 11). If cooling fan does not operate, go to step 12).
8. Repair open in battery feed circuit. After repairs, go to step 23).
9. Repair short to voltage in cooling fan battery feed circuit. After repairs, go to step 23).
10. Connect test light battery voltage and probe cooling fan control circuit. If test light illuminates, go to step 13). If test light does not illuminate, go to step 21).
11. Connect test light to battery voltage and probe cooling fan control circuit. Using scan tool, command cooling fan on. If test light illuminates, go to step 14). If test light does not illuminate, go to step 15).
12. With jumper wire still connected, disconnect cooling fan harness connector. Using test light connected to ground, probe cooling fan battery feed circuit. If test light illuminates, go to step 16). If test light does not illuminate, go to step 17).
13. Repair short to ground in cooling fan control circuit. After repairs, go to step 23).
14. Check terminals to cooling fan relay. Repair as necessary. After repairs, go to step 23). If terminals are okay, go to step 21).
15. Check cooling fan control circuit for open or poor connection. Repair as necessary. After repairs, go to step 23). If circuit or connection is okay, go to step 22).
16. Connect test light to battery voltage and probe cooling fan ground circuit. If test light illuminates, go to step 1icon_cool.gif. If test light does not illuminate, go to step 19).
17. Repair open or poor connection in cooling fan ignition feed circuit. After repairs, go to step 23).
18. Check for poor connections at cooling fan harness connector. Repair as necessary. After repairs, go to step 23). If connections are okay, go to step 20).
19. Repair open or poor connection in cooling fan ground circuit. After repairs, go to step 23).
20. Replace cooling fan motor. After replacing cooling and motor, go step 23).
21. Replace cooling fan relay. After replacing relay, go to step 23).
22. Replace PCM. Program replacement PCM using required equipment. After replacing PCM, go to next step.
23. Turn ignition on, with engine off. Command cooling fan on. If cooling fan operates, system is okay. If cooling fan does not operate, repeat step 1).
May 16, 2010 | 2000 Pontiac Grand Am GT
Oil cold engine
Some manufacturers use a hybrid cooling method where engine oil is circulated between the engine case and a small radiator. Here the oil doubles as cooling liquid, prompting the name "oil-cooling." Suzuki has produced many "oil-cooled" motorcycles.
Nov 20, 2008 | 1989 Suzuki Rg 250
Heating & Cooling Logo
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
