Question about Samsung Refrigerators
Can't get fridge to level. It is high on the front.
    President:
  • 704 Answers
It could be that the leveling bolts have been damaged and you aren't able to adjust them properly. If that is the case, you can attempt to correct the problem by using a ratcheting wrench to raise/lower them to re-thread them, however this doens't always work.
You may need to put down a piece of plywood at the rear of the fridge to get it more level, but remember that you don't want the fridge to be perfectly level anyway, as having the front slightly higher than the rear of the unit will allow the doors to "auto close" when opened to 90 degrees or less, especially nice when small children are in the house and don't always make sure the door(s) are closed when they're done.
Also most manufacturers design their fridges to be installed with the front just slightly higher than the back to aid in drainage of water produced when the unit goes into the defrost cycle every 8 to 24 hours. Hope this helps.
Posted on Jul 13, 2009
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
How do I level my fridge?
It is rare that the rear wheels adjust. Most of the adjustment is in the front wheels. They sometimes put screw jacks in the front as well.
Jul 24, 2014 | Kenmore Refrigerators
How do i lower the rear wheels? The back end sits flat on the floor but the front is raised higher because the nylon wheels are fully retracted. I will also need to level out the fridge.
set the level that backside of the fridge must be lower than front side,so that doors may,must be closed automatically after open the fridge
Jul 08, 2014 | Amana ASD2620HRW
Door not closing
The fridge should be slightly high in the front not level.
Jan 06, 2014 | Maytag MSD2732GR Side by Side Refrigerator
The fridge door will not stay closed. I changed the gasket, tightened the door screws, cleaned the contact area and it still pops open.
After all the good ideas you've already tried, the next things on your list could be:
(a) level the floor under the fridge - they often sag under the heavy weight of a loaded fridge due to moisture/rot.
(b) level the fridge itself - using the leveling legs. If the fridge continues to have a problem with
the door poping open, try raising up the front of the fridge above level.
(c) unload the door pockets - making the doors lighter may help solve the problem.
Aug 17, 2011 | Refrigerators
The ice maker is making a noise that sounds like it is unable to break the ice. I took a hair dryer to it once and melted the ice until it was able to finally eject it. I thought it was a one time problem...
Sounds like the ice is sticking too well to the tray.
You could consider coating the surfaces with something nonstick, such as ArmorAll, or Pam.
Perhaps they sell a teflon coated tray?
Jan 25, 2011 | Amana ATB1832AR Top Freezer Refrigerator
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
Front too high
The feet of the fridge can turn to adjust the height
Nov 17, 2009 | Refrigerators
The fridge is unlevel front to back. The front is relatively too high. How do I level the beast?
The front should be a "little" higher than the back, in order that the doors will close softly when pushed past a certain point, and to assist in sealing the door to the cabinet. There is a levelling mechanism on the front rollers, turning a screw or bolt head clockwise will raise the rollers and counterclockwise will lower the rollers. If no rollers, then post type feet that screw in and out for height. Most have rollers in front and these can be adjusted with the screw or bolt that you can see in the front behind the lower cabinet cover. It should lift and pull straight out to remove, and you will then see the adjustment bolts or screws. You should be about half a bubble out of true level for the doors to seal well and close softly.
Sep 26, 2009 | Samsung RF265AA Bottom Freezer French Door...
Samsung fridge freezer rsh1dtmh1/xeu
the only way is to remove the middle wheel right at the front this allows adjustment with the 2 feet at the front
Mar 20, 2008 | Refrigerators
Refrigerators Logo
192 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
