Question about Samsung SCH-a950 Cellular Phone
Transflash disk for samsung A-950
I just received a SanDisk for my A-950. Im for sure if its the right disk or even how to install it into my phone.
If it is a MicroSD, it should be fine. With the phone off and open so you can see the keypad, on the right-hand side of the keypad, you should see s rectangular cover that says 'Transflash'. Open the cover and insert the MicroSD card with the gold contacts facing up (toward the keypad). The slot is spring loaded, so push the card in until you hear a soft click. Then close the cover and turn on your phone. That should be it. Removal is the opposite. Just gently push in on the card to release it and it will slide out under the spring pressure.
The phone won't really acknowledge that the card is present but you can see how much room is available under Tools-System-Manage Memory.
Posted on Jan 03, 2008
How do i hear my messages on my at&t 950 corded phone ...I know my pin password
There is no button on this model of phone to automatically check your messages.
You will have to dial the access number that your local phone company uses to access the messaging system. On many systems the access number is *98 (Star 98) or it is simply dialing your own phone number, then entering your PIN number. Just check with your local phone service provider for the exact procedure in your area.
If you want, you can download the free manual for that phone from the following link:
http://www.retrevo.com/support/AT%26T-950-Telephones-manual/id/473ci257/t/2/
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Good luck.
May 10, 2011 | AT&T 950 Corded Phone
I plug my sandisk into my labtop im trying put my information thats on the labtop onto the sandisk but 0n my labtop the the icon shows for the sandisk but i cant send the information to the disk
How many removable drives did you see? Right Click on that drive then click <Properties>. If can see only blue color on the pie or the Free/Used Space is 0 bytes. Then your memory card may not be detected or is not supported by your reader. Try unplugging your sandisk.
Mar 20, 2011 | Computers & Internet
My memory card corrupted by my pc simply because im not safely eject hardware. i accidentally format it now from 1gb turn to 128kb..how can i restore to 1gb pls help me..thanks..
Connect your sandisk to computer thne right click on my computer icon then click on MANAGE then clcik on disk management then you find removable media you see there unpartitioned space of your sandisk .
Just right clcik on it then create partition .
Then check.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | SanDisk Extreme USB 2.0 Memory Card Reader
Cannot access and Format SanDisk 512MB memory Stick PRO Duo
Hi sir
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jun 26, 2009 | SanDisk Memory Media
HELLO...WE HAVE AN HP PSC 950 PRINTER, COPIER, SCANNER , FAX AND IT PRINTS SUPER SLOW...THIS HAPPENED BEFORE AND I PUSHED A BUTTON TO CORRECT THE PROBLEM BUT IM NOT HAVING THE SAME LUCK THIS TIME...HELP!!
I would seem the quality is set to high instead of normal or draft (even faster). Right-click on the printer in the Printers and Faxes folder and select Properties. Under Printing Preferences you can set the default quality. When printing photos you can override this setting.
Dec 30, 2008 | HP PSC 950 All-In-One InkJet Printer
Computer not recognizing my sandisk m240 mp3 player.
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..tghat is very important....once you do that..open up your windows media player...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Jul 18, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk micro
you should be in the disk managment area
my computer---right click-------manage--------- disk managment------ and see for your disk there---right click---- add new volume......
Jun 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Philips USB 2.0 MOBILE DISK
I have answered one of the similar questions earlier, please look at this it similar to yours: how many drive letter you have on your system?
make sure your drive is inside the usb port. I assume you are running windows system. Right click on my computer, click manage, then click disk management. Can you see your flash drive there, right click over it and assign a drive letter and thats it, you should see it.
Or
disconnect any f drives which you have by simply right clicking and disconnect, your flash drive should show you right away.
Or
Install any drivers which came with the drive and you should see it.
Hope that helped!
Dec 08, 2007 | Computers & Internet
Freezing
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line. We do apologize for any kind inconvenience this issue is causing you. For verification, does your computer have Windows XP as its operating system? This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution. Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding. If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer. Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer. To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again. We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data. Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears. After formatting the Sansa m240, please do try your Sansa m240. If applicable, please go the link below to download the firmware update for your Sansa m240. The link is: http://www.sandisk.com/Retail/Default.aspx?CatID=1326 or http://www.sandisk.com/Retail/Default.aspx?CatID=1376 If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer. NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
Samsung SCH-a950 Cellular Phone Logo
101 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
