Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
HP Pavillion won't turn on.
I just upgraded my video card and cleaned years of dust from the inside of the case while it was open. Now it will not turn on. Tested power cord and the green light is flashing on the ATX-300-12Z power supply. Sprayed compressed air on the power supply during cleaning.
  • brian400 Jul 14, 2009
    I got nothing when I tried to turn it on after installing the card. No fan movement, nothing and the green light on the PS is flashing. As if it wasn't plugged in, except for the flashing light on the pwer supply. Tested power cord on another PC and it worked fine. I am putting in a larger PS as we speak... 300 being replaced with a new 450.
  • Mike Lange May 11, 2010
    Have you had it on since you installed the new card? RU getting any of the operating lights flashing as normal? Harddrive, ON light etc?
  • 130 Answers
Hmm, did the CA damage any part of it? Sounds silly I know.
And is the power in the, Optical Disk Drive, HDD, Graphics Card and of course on the Motherboard?
Keep it on for about 40 minutes monitoring the heat ever so often even though there is nothing on the Monitor.
By the 40 Minutes it should be mid temp - Hot.
Best of Luck. Tom.
Posted on Jul 13, 2009
Ato x600 hp pavillion won't boot
You could try disabling the on board video in BIOS.
Feb 04, 2013 | HP Pavilion Computers & Internet
My HP Pavillion dv9000 laptop computer is 3 years old. All seems good until I stream video and it struggles to play the video cleanly. The internet connection is fine and when using other computers it...
No, there aren't any settings that can change graphic resolution on streaming video. However, you can visit the following website to update your drivers for your video card:
http://www.nvidia.com/Download/index.aspx?lang=en-us
There are two options on the website; option 1 is to fill in the info of your graphics card, and option 2 allows the nVidia website to scan your computer's hardware to find any updates needed. Option 2 is probably the safer route. Continue to follow the instructions until you have updated your graphics card drivers. This should enhance streaming video resolution.
Jul 17, 2011 | Computers & Internet
I have no signal on my moniter after i opened and cleaned it please help
you opened the monitor up physically? IE: took it apart and cleaned the inside where all the circuitry is? i think you have irreparably damaged the monitor..
Jun 18, 2011 | HP Pavillion s7420n PC Desktop
I have a hp m820n and it crashes or won't start and has a long beep then a short beep i am wanting to know if that is the motherboard that is crashed
Hi.
This could be one of 2 problems.
1, there is a system memory problem. Open the case and carefully clean the inside of dust. Next, remove the memory modules and clean the slots with a soft, dry paintbrush, also clean the brass contacts that run all the way down one side of the memory.
The memory modules look like this >>>>>
2, there could also be a problem with the graphics (video) card. Take it out and clean the contacts and the slots.
Hope this helps.
Regards.
May 17, 2011 | HP PAVILION M8200N PC Desktop
I have a hp pavilion a177c desktop. i opened the case to replace the SATA harddrive and SATA dvd rom and cmos battery. also cleaned out all the dust i could see(which was almost none). after hooking...
You don't say how you cleaned the motherboard. It only takes a small knock or static spark to kill electronics. PCI and I/O control is done by a chip on the motherboard and if this is fried you will need a new motherboard. The only way to check is with specialist hardware. take it to a computer repair specialist ( not PC world- too expensive) the cmos battery shouldn't have needed replacement after a maximum of 5 years. I have batteries that have lasted over 20 years. incidentally if you have replaced the cmos battery you would have to setup the bios again anyway.
Apr 04, 2011 | HP Computers & Internet
How do I open up my HP Pavillion zd800 case. I want to clean out the dust.
You don't need to open it up!
Turn the computer off.
Remove the battery.
Buy a can of compressed air, and give your computer a "blow-job" through every vent that you can find.
Follow the instructions on the can -- keep the can "vertical" while using it.
May 31, 2010 | HP Pavilion zd8000 Notebook
My sony laptop computer has big noise when the fan start.
It is normal for the computer to do this. When an application you are running makes greater use of the CPU, memory, video card, and disk drives, power consumption increases, and the fan either kicks up in speed or turns on. If the sound is annoying, you may be able to reduce the fan cycles by cleaning the dust out of the computer case.
Get a can or two of Dust-Air or a similar product.
Open the case of your computer by removing the screws on the back. Some computer cases have easy-open latches, so you may not need tools. Use a vacuum cleaner to get the bigger dust bunnies out of the case, then use the Dust-air to blow out all of the nooks and crannies. Make sure to blow out the heat sink for the CPU; the vanes tend to clog with dust. Blow off the vanes of all the cooling fans, too. There will be one on the CPU, and probably a few others, e.g., most video cards have their own fans and heat sinks now.
Replacing the case fan with a quieter model, such as a Vantec, can also help:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=674644&sku=V13-4009
Computer makers build systems with the cheapest parts they can get their hands on, and if you're handy, it's worthwhile upgrading.
Warm regards,
Anirban Mazumdar
Nov 05, 2009 | Sony CPU FAN CPU Fan
Graphics Card Upgrade for HP Pavillion a6600f
if your video slot is a agp try buy a nvidia geforce 7800gs used on ebay cheap and good ;p if u have a pci-x slot u can have a better card also check your power suppy if is enough for it you can ask to a reseller near you cya
Jun 03, 2009 | Computers & Internet
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
275 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
