Takes over an hour to brew a pot of coffee.
SOURCE: brew time
If you have hard water, minerals may have built up in the unit, slowing down the flow. You should be able to find some sort of mineral-dissolving treatment for it at your local grocery or hardware store. Make sure to run a few pots of plain water when you are done, to get any residue out!
SOURCE: Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
SOURCE: Mr. Coffee won't brew all the coffee in the resevior
I would say you need to change the filter on it.
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
SOURCE: My Mr Coffee ISX43 gurgles upon start up and
The main burner needs replaced, and its cheaper to just buy a new maker...also the parts are not readily available to the consumer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
