Question about Mitsubishi VS-50605 50" Rear Projection Television
When I toggle the input button it only goes between Ant-A and Ant-B with a blue screen and not input. After about a minute the set automatically turns off. What has caused this to occur?
    President:
  • 788 Answers
If you are able to pull up the menu, I think that I can help you fix this problem.
Your symptoms sounds like that your input is fixed to the input one or video one input.
I have seen this many times and it can be fixed rather simply.
If you can pull up the menu, you can fix this with the remote.
You will need to pull up the menu and change the option of Home Theater to off.
I think that this is in the advanced menu from the main menu.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 13, 2009
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
Have a blue screen and sound, and when i click my input buttons i only have ant-A and ant-B no inputs 1-2-3 or dvd
I would call Mitsubishi if you have the original remote the set may have (most do) a hard reset that will restore all inputs.
It consists of a 4 digit code by model number, I have a list of the codes somewhere(I am on the road today) and with the set on you enter the numbers and the set turns off and comes back on reset.
SD TECH
Apr 14, 2011 | Mitsubishi VS-50604 50" Rear Projection...
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Tv comes on i see polaroid then turns to a blank screen. But the blue light stays. it is a polaroid tla 0911 c
Check to see that the video input is set toth correct setting. ie/ cable/ant. t sounds as though it may be set to a video input like a DVD or Blue Ray or VCR.
Jan 16, 2010 | Televison & Video
How do i get from a blue sceen to a tv channel
on that set use the input button, it is located under the 9. Kepp tapping it untill ANT is highlighted
Jul 07, 2009 | Toshiba 42HL167 42 in. LCD Television
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Blue screen
Try pressing the "Input" button a click at a time and see if the OSD (On Screen Display) cycles through Ant A, ANT B, AV1 and so on...
Bill
Nov 11, 2007 | Mitsubishi WS-73615 73" TV
Hitachi 50V500
Turn off your set. ( wait for the light and the fan to shut down) push and hold the Input button on the panel, power it on with the power button on the tv, as soon as you see the service menu appear, let go of the input button. Scroll down to : LCD adjust, toggle blue button to the right, another screen will appear. Adjust the squares on the screen until the ghosts are gone. hit Exit twice::Ghosts are Busted!
Aug 02, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
