Question about Frigidaire ATF6000ES Front Load Washer
It smells like musty water inside the machine and is leaving that smell on clothes and towels
  • 132 Answers
It is very good q
advice in secret do 2 things
1-{ washing without soap without clothes in maximum temperature like 95 oC in cotton programm } do that every mounth
2- after complet any washing programm leave door of m/c open for just 15 minutes
thanks
Posted on Jul 13, 2009
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have never liked my lg and now it seems that
You might check the water inlet valve on the back of the machine where the water hooks up. There should be a blue plastic water valve. remove the water hose on both sides hot and cold. At the blue water inlet valve inside the connector there are small filtering screens (similar to an areator valve on your sink faucet) They may be clogged by sediment and this would cause your low water issue and possibly the smell. Simply pull out the screens with a pair of needle nosed pliers and replace. Hope this helped
Dave
Nov 05, 2009 | LG WM2016C
Smelly clothes after washing
yes musty is actually cooked soap
from the dryer
take a clean just washed towel and put it in the washer alone with no soap
turn on the machine and watch what happens you will see the suds start to form
with this unit, if your using too much soap it will be spun into the cloths and then cooked in the dryer
do one towel load without soap then cut you soap usage way back
anything more than a tablespoon is way to much
remember you bought this unit to save water
1/6 the water 1/6 the soap
and he should be less
Oct 24, 2009 | Maytag MAH2400A Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Musty smell
Run your machine through its cycle with NO clothes and when it is filling up with water put bleach in the water. Put bleach in only at the start of cycle.
Before you do this clean all inside parts the best you can yes with bleach and you can run something like fleecy to make clothes soft and smell nice when you wash your clothes as well. Our machine has a special holder to put softener in.
Do NOT have clothes in when running the heavy bleach through it. This should kill the bacteria .
Aug 12, 2017 | Maytag ATW4475TQ Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Smells of mildew and so do clothes
Hi! I have Kenmore Elite 4t and had this same problem: Musty, Moldy smell in washer and on clothes. The Sears Technician suggested that I use a half a cup of Clorox Liquid Bleach and put it in the tub (not the dispenser). NO CLOTHES! Use the longest hottest setting and when it's done clean the inside (underneath rubber tire thingie) and the undernath part of the door with a papertowel. And to always leave the door open. I did what he said with the bleach and it worked. I didn't want to leave the door open because I have 2 cats & was afraid that they would want to go in it, but ended up repeating the bleach thing again because a few days later the horrible smell was back. I leave the door open all the time now and the cats never go in it. They've watched laundry spin around, so I guess they're smart enough to not want to go in it. I have not had this problem again since I always leave the door open and I did this over a month ago. I hope this helps!
Jan 10, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
282 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
