Question about Samsung Televison & Video
Got a pop last week & t.v went off. Replaced lamp and it acts like it wants to come on but all 3 indicator lights blink and then it shuts off. the lamp doesn't fire up so the screen stays black
  • 261 Answers
It seems like your ballast doesn't have enough voltage to keep up with your new lamp, the best thing to do here is to replace the lamp, you should be good after that.
Posted on Jul 14, 2009
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Cooling fan on sony wega model kdf50e2000 not working, tv shuts down replaced lamp last week
The set should if shuts down have the power light blink a specific code or number of blinks-----3 blinks?
Mar 26, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
I have the Samsung HLN5065W DLP television, and if I press the power button the TV will act like it is going to power on but won't. The lamp light will blink but I never get a picture. It seems like it...
It seems tv needs lamp replacement, please check lamp in tv and if lamp has not been replaced in last 2-3 years or lamp is broken, replace it to solve tv problem.
Thanks.
Jan 22, 2011 | Samsung HLN5065W 50" Rear Projection...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Newlamp went out in 20 days. lamp light blinks. is lamp dead now?
Biggest problem with DLP tv's is they get dirty (the usually have two or more fans...one in the back w/filter and one under the lamp). If air-flow is restricted the life of the lamp is in jeopardy. Verify air flow & clean filter(s). Replace lamp with exact P/N..not those that say they "are equivalent"...they are not. Also, be sure the lamp lens is very clean.
Apr 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi Televison & Video
Pop then dark screen - no picture... New lamp installed and still no picture
Yes you are correct, I have seen this many times. 6 flashes is the thermal fuse
Mar 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
