Question about Dell Inspiron 9100 XPS Latitude D400 Latitude D505 CDRW/ DVD Combo - C0932 CD-ROM Drive
I Have a 9100 xps with a new battery and it only charges to 30%
  • 358 Answers
I would advice you to try another Charger first.
This is because I have seen a case like that where we thought it was the battery that was faulty until we just decided to try a friend's charger instead...and you know what? It gave us 2hrs 45 minutes 100% Full-Bar Battery life.
So please try and check it with another charger first.
Hope this helps you out.
Posted on Jul 13, 2009
I get 5 short beeps when I turn the computer on. what does that mean?
Marty,
The 5 beep code on the XPS 9100 refers to a CMOS Battery Failure. You can click the link below to download the online manual. The manual provides information on removing/replacing parts within your computer.
http://dell.to/1GTRXZt
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 24, 2015 | Dell 5DN3X System Board for Studio XPS...
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Dell xps 9100 wireless stopped working
it sounds like the drivers were uninstalled.
May 21, 2012 | Dell Studio Xps 9100 Desktop Computer
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Solo 9100 battery
Well, 8 years is an excellent life for any laptop battery. Being that old it will either be a nicad or nimh battery, both of which suffer from battery memory. There is very little you can do. Sometimes, charging the battery as much as possible, REMOVE IT FROM THE LAPTOP, put it into a plastic bag, seal it against moisture, and then put it into a freezer for 12 hours. Replace it into the laptop, charge it again, repeat twice more. If the battery has a bit of life in it you may be able to reclain SOME of it's capacity back. This is a last ditch effort, and should be carried out as a last option. That leaves either buying a new battery, this eBay link will take you to one
http://cgi.ebay.co.uk/NEW-Laptop-Battery-for-Gateway-Solo-2300-2500-9100-9150_W0QQitemZ230370600615QQcmdZViewItemQQptZLaptop_Batteries?hash=item35a32866a7
It's probably time to replace the whole laptop though.
Hope this helps
Jan 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
No light in the battery indicator when i charge
it must be that the notebook is running on battery or ur battery is fully charged
Thanks for using Fixya
May 06, 2009 | Dell Inspiron 9100 Notebook
Dell inspiron xps 9100 cpu upgrade
Highest compatible cpu for your system is the Pentium 4 3.6 ghz Prescott. Hope this helps & please rate this solution fixya. Thanks.
Here is a link to a spare parts supplier for your system: http://www.dellweb.co.uk/spares/inspiron/9100.htm
Feb 04, 2009 | Dell Inspiron 9100 Notebook
A hardware fault
the battery may not be fully charged here is a simply fix use a toothbrush and clean the contacts on the battery and on the computer itself,check also that the blower vents are not blocked and you have good air flow.try again time it see how long it last.Failing that you might have a failing battery.
Good luck
Dec 22, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Dell Inspiron 9100 XPS Latitude D400 Latitude D505 CDRW/ DVD Combo - C0932 CD-ROM Drive Logo
67 people viewed this question
Alun Cox
