Question about Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 I keep getting a end toner life message after replacing cartridge
  • 46 Answers
Make sure the machine is not in direct sunlight as the toner end sensor is photo-optic. If it's an after market toner or refill...good luck with that. Lastly remove the toner tap on top of it and shake it from side to side and reinstall. The toner may be caked up inside,
Posted on Aug 28, 2009
  • Rick Sep 03, 2009
    Also, If you remove the toner unit and look at the sides there is a round plastic window about a 1/4 inch in diameter on bothe sides. If you aim one end towards a bright light and look from the other end and see light this means that it's empty. If you can't see light it is full. This does take a little practice to get the alignment right in order to see the light through the toner unit and make sure its level while you are doing this.
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
Toner life
You need to reset your Brother printer to get rid of the message
Mar 26, 2008 | Brother IntelliFax-2820 Laser Fax
"toner life end" message even with new cartridge
Open the front cover
Press the OPTIONS button
Press the START button
Press the number 1 key twice
Close the front cover.
You may need to go through the steps above twice to reset the toner.
Jul 11, 2010 | Brother IntelliFax-2820 Laser Fax
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
Said low toner cartridge. Replaced cartridge,
what is showing toner life end ? rajcanon007@yahoo.co.in
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
4. Press 1,0 .
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Feb 06, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
1,185 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
